[OpenLayers-Users] Problems using Layer.WMS.Post
Andreas Hocevar
ahocevar at opengeo.org
Wed Feb 17 11:33:19 EST 2010
you should use firebug to see what requests were issued and what was
returned. In your case, I suspect that the combination of LAYERS and
SLD_BODY params is invalid and you don't get back an image from your WMS.
Regards,
Andreas.
On 2010-02-17 16:47, David Alda Fernandez de Lezea wrote:
> Hello list,
> I had som problems applying a SLD to a OpenLayers.Layer.WMS becuase of the mentioned problem of URL length in IE. I followed up the discussions about this solution and decided to apply it to my app. But I get an error when I try to apply an SLD and make it visible. I mean, I create the layer without any error:
> olLayers[0] = new OpenLayers.Layer.WMS.Post( "WMSLayer",url,
> { transparent: 'true', layers: 'RecintosSigpac,ParcelasSigpac,PoligonosSigpac'},{visibility: false, displayInLayerSwitcher:false, isBaseLayer: false, units: 'm', maxExtent: new OpenLayers.Bounds(460000, 4710000, 610000, 4820000), maxResolution: 292.96875} );
> Then, later, I have some links that the user can click to apply some SLD's to some parcels. I create the SLD dynamically.
> var wms = this.map.getLayersByName("megaWMSLayer")[0];
> wms.mergeNewParams({SLD_BODY: sld});
> wms.setVisibility(true);
> And the problem comes in the line 'wms.setVisibility(true);'. Debugging the error, I found that it crashes in line 1275 character 174 of OpenLayers.js to be precise. This is the code of that line:
> tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
> this.numLoadingTiles++;};
> And the variable tile is undefined.
> Is this a known problem or it's just my fault??.
> Any ideas??
> Thanks in advance.
> Un saludo,
> David Alda Fernández de Lezea
> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
> IKT
> Granja Modelo s/n · 01192 · Arkaute (Araba)
> Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
> email: dalda at ikt.es web: www.ikt.es
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
