[OpenLayers-Users] Problems using Layer.WMS.Post
David Alda Fernandez de Lezea
dalda at ikt.es
Thu Feb 18 04:00:33 EST 2010
Thanks for your help. What does trunk mean??
Whenever a change is made, another build is also made? And is available as one file only?? I'm a bit confused withs names (trunk, nightly build, etc)
If I create my own control, how can I add the control to this .js file??
Thanks again.
-----Mensaje original-----
De: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] En nombre de Andreas Hocevar
Enviado el: jueves, 18 de febrero de 2010 9:47
Para: users at openlayers.org
Asunto: Re: [OpenLayers-Users] Problems using Layer.WMS.Post
please use a current trunk version of OpenLayers, not a patched 2.8 version. You can download a nightly build from http://trac.openlayers.org/wiki/HowToDownload
Regards,
Andreas.
On 2010-02-18 08:59, David Alda Fernandez de Lezea wrote:
> Hello, thanks for your response.
> I'm trying to make it work in IE so I guess Firebug is not very useful in this case. Maybe I didn't mention, but it works in FF, Chrome and Safari, the only problematic browser is IE, which has the limitation I mentioned. Digging a little bit in the code I found that an OL class was missing to get WMS.Post work. This class was IFrame.js, but know I've got another error pointing this class:
> In method 'createRequestForm'
> form.action = OpenLayers.Util.urlAppend(this.layer.url, cacheId);
> Saying that the object doesn't accept function urlAppend. Again, digging into the code I found that the class Util.js doesnt' have the function urlAppend, and I've started wondering how many classes do I have to update to make this work. Are there some instructions to apply this change or some info about the classes involved in this change??
> Where I can find the new Util.js for download??
> Thanks.
> En nombre de Andreas Hocevar Enviado el: miércoles, 17 de febrero de
> 2010 17:33
> Hi,
> you should use firebug to see what requests were issued and what was returned. In your case, I suspect that the combination of LAYERS and SLD_BODY params is invalid and you don't get back an image from your WMS.
> Regards,
> Andreas.
> On 2010-02-17 16:47, David Alda Fernandez de Lezea wrote:
>> Hello list,
>> I had som problems applying a SLD to a OpenLayers.Layer.WMS becuase of the mentioned problem of URL length in IE. I followed up the discussions about this solution and decided to apply it to my app. But I get an error when I try to apply an SLD and make it visible. I mean, I create the layer without any error:
>> olLayers[0] = new OpenLayers.Layer.WMS.Post( "WMSLayer",url,
>> { transparent: 'true', layers:
>> 'RecintosSigpac,ParcelasSigpac,PoligonosSigpac'},{visibility: false,
>> displayInLayerSwitcher:false, isBaseLayer: false, units: 'm',
>> maxExtent: new OpenLayers.Bounds(460000, 4710000, 610000, 4820000),
>> maxResolution: 292.96875} );
>> Then, later, I have some links that the user can click to apply some SLD's to some parcels. I create the SLD dynamically.
>> var wms = this.map.getLayersByName("megaWMSLayer")[0];
>> wms.mergeNewParams({SLD_BODY: sld});
>> wms.setVisibility(true);
>> And the problem comes in the line 'wms.setVisibility(true);'. Debugging the error, I found that it crashes in line 1275 character 174 of OpenLayers.js to be precise. This is the code of that line:
>> tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.t
>> r
>> iggerEvent("loadstart");}
>> this.numLoadingTiles++;};
>> And the variable tile is undefined.
>> Is this a known problem or it's just my fault??.
>> Any ideas??
>> Thanks in advance.
>> Un saludo,
>> David Alda Fernández de Lezea
>> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y
>> Biodiversidad
>> IKT
>> Granja Modelo s/n · 01192 · Arkaute (Araba)
>> Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
>> email: dalda at ikt.es web: www.ikt.es
>> · ············ _______________________________________________
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users mailing list
Andreas Hocevar
Users mailing list
