[OpenLayers-Users] rewrite 00-map-with-wms.html in GWT and org.gwtopenmaps.openlayers library
paweluz paweluz at o2.pl
Thu Feb 18 06:57:38 EST 2010
Hi Jim!
I have this same problem!!!! Did you manage to deal with it?? I tried
everything, on different server (glassfish, Jetty) and the problem still
occurs. Please write to me whether you found the solution...
Cheers,
Poul
www.gwtorm.com wrote:
> Anybody uses GWT and org.gwtopenmaps library for Google maps.
> When I convert js version into GWT version, Google map just occurs in
> upper
> left of map widget instead of whole part of map widget. After I resize web
> browser and change zoom level, I can get the same look as original js
> version.
View this message in context: http://n2.nabble.com/rewrite-00-map-with-wms-html-in-GWT-and-org-gwtopenmaps-openlayers-library-tp3503835p4591336.html
