[OpenLayers-Users] Appliaction loads the first google tile and
then gives up
Andreas Hocevar
ahocevar at opengeo.org
Thu Feb 18 07:49:08 EST 2010
On 2010-02-18 13:36, paweluz wrote:
> I have this same problem. Did anyone solve it?? Please write ....
Make sure that your gwt plugin uses the latest nightly build of
OpenLayers, not version 2.8. These issues should all be fixed now.
Regards,
Andreas.
> agul wrote:
>> Hi David I faced the sama problem but I couldnt solve if you find a way
>> please write...
>> David Potts wrote:
>>> Hi
>>> Am trying to load a google map via the gwt plug in and its not working.
>>> As far as I can tell openlayers is correctly requesting the map tiles
>>> from google maps(I have traced the net connection via firefox and you
>>> can see all the tiles being downloaded)
>>> When the program loads, a google map is shown in the left hand side of
>>> the viewport, but its cliped to about a 3rd of the viewport.
>>> If you scroll to the left or the right, the next tile is loaded, the
>>> image now takes up two thirds of the viewport.
>>> If you scroll to far to the right, the image drops back to left hand 1/3
>>> of the viewport.
>>> Dave.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
