[OpenLayers-Users] click/hover select controls on one layer
Andreas Hocevar
ahocevar at opengeo.org
Thu Feb 18 13:01:57 EST 2010
Andreas Hocevar wrote:
> Hi Rob,
> Robert Marianski wrote:
>> I want to be able to handle both hover and click events on features in a
>> vector layer. I created two select controls, one with hover set to true,
>> added them to the layer, and activated them.
>> What I'm seeing is that the click select control doesn't receive any of
>> featured selected events, but the hover select control does receive the
>> hover events. If I don't add the hover select control but only the click
>> select control, then I do receive all the click events.
> This is because by default, hovering over a feature also selects it. You
> can change that easily by configuring the one that you use for hover with
> highlightOnly: true
Meaning, configure the SelectFeature control that you use for hovering with:
hover: true,
highlightOnly: true
Regards,
Andreas.
> Hope this helps,
> Andreas.
>> Am I approaching this the wrong way? Any workarounds? I'm using the
>> nightly openlayers build from 2/17/10.
>> Thanks,
>> Robert
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
