[OpenLayers-Users] Multiple invoke by zoom, very bad performance
bartvde at osgis.nl
bartvde at osgis.nl
Fri Feb 19 09:07:12 EST 2010
Does this happen with normal zoom or with the mousewheel zoom?
If with the mousehweel zoom, check the new options (in OL trunk) for the
MouseWheel handler:
* Property: interval
* {Integer} In order to increase server performance, an interval (in
* milliseconds) can be set to reduce the number of up/down events
* called. If set, a new up/down event will not be set until the
* interval has passed.
* Defaults to 0, meaning no interval.
interval: 0,
* Property: delta
* {Integer} When interval is set, delta collects the mousewheel z-deltas
* of the events that occur within the interval.
* See also the cumulative option
delta: 0,
* Property: cumulative
* {Boolean} When interval is set: true to collect all the mousewheel
* z-deltas, false to only record the delta direction (positive or
* negative)
cumulative: true,
Best regards,
Bart
> Hi Marc, thank you very much for your attention.
> The test is very simple:
> in jsp: invke the map throughout servlet:
> map = new OpenLayers.Map( 'map' );
> layer = new OpenLayers.Layer.WMS(
> "SampleWMS",
> "OpenlayerZoomMultipleInvoke",//invoke the serlvlet
> {layers: 'sea_ice_concentration_02'},
> {singleTile: true}
> int the servlet: I catch the parameter (getParameter layer, bbxo, etc...)
> and load the rul, for example:
> url = server + request.getParameter("BBOX") + ....; and print a message:
> System.out.println("invoke the map");
> The message is print 2^n times (n = #zoom), ie: zoom=2 => message print 4
> times...zoom=4=>16 times...
> Thanks, Marck
> http://n2.nabble.com/Multiple-invoke-by-zoom-very-bad-performance-tp4595600p4597953.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
