[OpenLayers-Users] Changing the width of the LayerSwitcher?
Andreas Hocevar ahocevar at opengeo.org
Mon Feb 22 11:18:20 EST 2010
Robert Hicks wrote:
> Hey all, is there an easy way to do this? I tried the plain old CSS
> approach by referencing the class name(s):
>             div.olControlLayerSwitcher {
>             	width: 250px;
>             div.olControlNoSelect {
>             	width: 250px;
> But no luck. I also tried maximizeDiv:true in the objects constructor
> but no changes. Ideas?
The above (for .olControlLayerSwitcher) should work if you are using the
current trunk version, and include theme/default/style.css before the
above declarations. If you are still using OpenLayers 2.8, you can try
to make the width declaration of .olControlLayerSwitcher !important.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
