[OpenLayers-Users] Problems with GetFeatureInfo
Vince Lotito vince at vvl.com
Tue Feb 23 06:40:55 EST 2010
It sounds like a security issue. Are your web page/scripts being served from http://hboard.iwk.uni-karlsruhe.de:8080<http://hboard.iwk.uni-karlsruhe.de:8080/>? If you are not then your HTTP response will be blank.
Kind Regards
Vince
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Al Zi
Sent: Tuesday, February 23, 2010 5:22 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] Problems with GetFeatureInfo
Dear All,
OpenLayers used together with geoserver 2, tomcat6, Sun Java 6 on Ubuntu server 64 bit.
while trying to use GetFeatureInfo following problems appear:
1) if using GetFeatureInfo like this:
        map.events.register('click', map, function (e) {
                    document.getElementById('nodelist').innerHTML = "Loading ... please wait ...";
                    var params = {
                        REQUEST: "GetFeatureInfo",
                        EXCEPTIONS: "application/vnd.ogc.se_xml",
                        BBOX: map.getExtent().toBBOX(),
                        X: e.xy.x,
                        Y: e.xy.y,
                        INFO_FORMAT: 'text/html',
                        QUERY_LAYERS: map.layers[0].params.LAYERS,
                        FEATURE_COUNT: 50,
                        Srs: 'EPSG:32638',
                        Layers: 'Moskva',
                        Styles: '',
                        WIDTH: map.size.w,
                        HEIGHT: map.size.h,
                        format: format};
                    OpenLayers.loadURL("http://hboard.iwk.uni-karlsruhe.de:8080/geoserver/wms", params, this, setHTML, setHTML);
                //    window.open("http://hboard.iwk.uni-karlsruhe.de:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=Moskva&styles=&bbox=-125830.05,6099218.02,153008.285,6277080.521&width=517&height=330&srs=EPSG:32638&format=application/openlayers");
                    OpenLayers.Event.stop(e);
        // sets the HTML provided into the nodelist element
        function setHTML(response){
            document.getElementById('nodelist').innerHTML = response.responseText;
clicking on maps brings up "Loading ... please wait ..." message only and nothing else.
2) if using in a way as described in http://trac.openlayers.org/wiki/GetFeatureInfo nothing happens at all.
3) I tried to save OpenLayers html provided by geoserver locally and it does not work as well. "Loading ... please wait ..." message appears for a short time then disappears and nothing happens
Any help would be highly appreciated.
Alex
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100223/5c0b6cf7/attachment.html
