[OpenLayers-Users] Beginner issue
ethio info info.ethio at gmail.com
Tue Feb 23 15:51:05 EST 2010
Sorry to keep pestering you, but does anyone know what I am doing wrong?
if anyone can make this work, and tell me how to fix it, I would be very
grateful.
thanks
On Sun, Feb 21, 2010 at 3:23 PM, ethio info <info.ethio at gmail.com> wrote:
> I understand what you are saying but my previous request was rejected
> because it was over the size limit.
> Here it is:
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
> http://www.w3.org/TR/html4/loose.dtd">
> <html>
> <head>
>     <meta http-equiv="Content-Type" content="text/html;charset=utf-8" />
>     <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7">
>     <!-- GLOBAL JAVASCRIPT -->
>     <script src="http://www.latimes.com/includes/projects/js/menu.js"
> type="text/javascript"></script>
>     <script src='
> http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ>
> '></script>
>     <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
>     <script type="text/javascript">
> var index_map;
> var wkt_f = new OpenLayers.Format.WKT();
> function load_index_map() {
> //    var max_extent = new
> OpenLayers.Bounds(860986,-4383204,5870363,3600489);  //working but no
> woreda's
> OpenLayers.Bounds(660986,-4383204,4870363,3600489);//not working
>     var options = {
>         projection: new OpenLayers.Projection("EPSG:900913"),
>         units: "m",
>         maxResolution: 156543.0339,
>         maxExtent: max_extent,
>         minZoomLevel: 10,
>         maxZoomLevel: 10,
>         controls: []
>     // Firing up the map object
>     index_map = new OpenLayers.Map('index-map', options);
>     // Google terrain map
>     var gphy = new OpenLayers.Layer.Google("Google Terrain", {
>         type: G_PHYSICAL_MAP,
>         "sphericalMercator": true
>     index_map.addLayer(gphy);
>     index_map.addControl(new OpenLayers.Control.LayerSwitcher());
>     index_map.addControl(new OpenLayers.Control.MousePosition());
>     // Setting the feature style
>     var template = {
>         strokeColor : '#2262CC',
>         strokeWidth: 2,
>         strokeOpacity: 0.9,
>         fillColor : '#2262CC',
>         fillOpacity : 0.3,
>         pointRadius : 3,
>         strokeLinecap: "round"
>     // Assigning the feature style
>     var style = new OpenLayers.Style(template);
>     var style_map = new OpenLayers.StyleMap({
>         'default': style,
>         'select': {
>             fillColor: '#2262CC',
>             fillOpacity: 0.75
>     var hood_vector = new OpenLayers.Layer.Vector("Wereda");
>     ar hood_polygon_371 = wkt_f.read('MULTIPOLYGON (((39.2968382026
> 8.8274792477, 39.3135039775    8.748488041, 39.3016324666    8.742095689,
> 39.3036871512    8.7357033371, 39.269899005    8.6920983646,
> 39.2315448931    8.6608214995, 39.2265223308    8.645982111,
> 39.2479823696    8.6108241751, 39.2249242428    8.589135838,
> 39.2221846634    8.5756662392, 39.2306316999    8.5656211146,
> 39.257114301    8.5601419558, 39.2502653525    8.5464440587,
> 39.2139659251    8.5220161421, 39.1744703218    8.4606039034,
> 39.0858905871    8.385037171, 39.0758454626    8.3950822956,
> 39.0381762455    8.399419963, 39.0363498593    8.5128842107,
> 39.0671701278    8.5432478827, 39.0655720398    8.5562608849,
> 39.0872603769    8.5968979797, 39.0874886751    8.6528310595, 39.10415445
> 8.6825098366, 39.0982186945    8.6939247509, 39.1075789242    8.7101339291,
> 39.1603158281    8.742095689, 39.1840588498    8.7877553461,
> 39.1767533046    8.8019098398, 39.2014095194    8.8146945437,
> 39.2057471869    8.8039645243, 39.2199016805    8.8012249449,
> 39.2461559833    8.8299905288, 39.2710404964    8.8224566854,
> 39.2968382026    8.8274792477 )))');
> hood_polygon_371.data = {'slug':' 371', 'name': '371'};
> var hood_polygon_260 = wkt_f.read('MULTIPOLYGON (((39.506872625
> 9.3384108099, 39.5290175587    9.3116999105, 39.510068801    9.2838475198,
> 39.522853505    9.2751721849, 39.4963709039    9.2509725667,
> 39.5105253976    9.2502876718, 39.5089273096    9.2354482833,
> 39.5290175587    9.2133033496, 39.5598378272    9.2203805965,
> 39.5456833335    9.1938979954, 39.5376928935    9.1470968469,
> 39.5771884968    9.0621698849, 39.5447701403    9.0523530586,
> 39.4872389725    9.0171951227, 39.461212968    9.0137706484,
> 39.4299361029    9.0452758117, 39.4004856241    9.0596586037,
> 39.3701219522    9.1025786813, 39.3758294093    9.126321703,
> 39.3498034048    9.1690134823, 39.2920439386    9.1770039223,
> 39.281085621    9.1865924503, 39.2514068439    9.2676383415,
> 39.2509502473    9.3203752454, 39.2584840907    9.3308769665,
> 39.266702829    9.3265392991, 39.3011758701    9.2909247666,
> 39.3253754883    9.3107867174, 39.3824500596    9.293664346, 39.434045472
> 9.3477710396, 39.4589299851    9.3511955139, 39.506872625    9.3384108099
> hood_polygon_260.data = {'slug':' 260', 'name': '260'};
> Wereda");
> (hood_vector.addFeatures([hood_polygon_260,hood_polygon_371);
>     var lon = 4387103;
>     var lat = 1007363;
>     var zoom = 0;
> function show_hood(feature) {
>         var selectedFeature = feature;
>         var hood_name = selectedFeature.data.name;
>         var hed = document.getElementById('hood-index-hed');
>         hed.innerHTML = 'Click to visit ' + hood_name;
>     function hide_hood() {
>         hed.innerHTML = "Select one of L.A.&rsquo;s 114 neighborhoods";
>     function click_hood(feature) {
>         var url = '/mapping-la/neighborhoods/neighborhood/' +
> selectedFeature.data.slug;
>         index_map.destroy();
>         window.location.href = url;
>         return false;
>     var hover_control = new OpenLayers.Control.SelectFeature(hood_vector, {
>         hover: true,
>         onSelect: show_hood,
>         onUnselect: hide_hood,
>         onHoverClick: click_hood
>     index_map.addControl(hover_control);
>     hover_control.activate();
>     </script>
> </head>
> <body onload="load_index_map()" ><h2 style="font-size: 3em;
> ">Woreda's</h2>
>     <div class="bottomborder pad5vert clear"
> style="margin-right:20px;"></div>
>     <!-- the dynamic hed -->
>     <h1 class="pad10vert" id="hood-index-hed" >Select one of the 583
> woreda's    </h1>
>     <!-- The index map -->
> <div id="index-map"  style="width: 1200px; height: 900px"></div>
> </body>
> </html>
> On Sun, Feb 21, 2010 at 10:40 AM, Nicholas Efremov-Kendall <
> n.e.kendall at gmail.com> wrote:
>> you really need to post more code than that for someone to be able to help
>> you. Are you using proj4.js to change your projection? OL only uses a few
>> projections/coordinate systems natively.
>> On Sun, Feb 21, 2010 at 2:39 AM, ethio info <info.ethio at gmail.com> wrote:
>>>  Hi, Please take a look at this site:
>>> http://projects.latimes.com/mapping-la/neighborhoods/.
>>> I have copied the source and cleaned it up of ads and so forth and have
>>> put in my data and I just can not see the overlay on the Google map.
>>> I will include the changes I made below.  The only thing I can think of
>>> that is blocking my overlay is the bounds.  Basically, I want the country of
>>> Ethiopia.
>>> Just to complicate things further, my overlay was showing when I did not
>>> use a spherical mercator projection but the overlay matched what is in
>>> Google maps ONLY when I zoomed in.
>>> so after reading some of the issues some people had, I figured I should
>>> use what is in the Mapping LA w/minor changes.
>>> Can someone suggest a solution?  BTW, the overlay switch works and gives
>>> my overlay as a check box option to click on but it is not displayed on the
>>> Google map
>>> Here are my changes to the Mapping LA Neighborhood source:
>>> var max_extent = new OpenLayers.Bounds(860986,-4383204,5870363,3600489);
>>> var hood_polygon_371 = wkt_f.read('MULTIPOLYGON (((39.2968382026
>>>     var lon = 4387103;
>>>     var lat = 1007363;
>>>     var zoom = 0;
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Fulbright Student 2009-2010, Ukraine
>> nefremov at artsci.wustl.edu
>> c/o Halyna Yerko
>> Balzaka 92a, Kv 27
>> 02232
>> Kyiv, Ukraine
>> (mob) +380963576524
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100223/185ddf42/attachment.html
