[OpenLayers-Users] about text layers
Alexandre Dube
adube at mapgears.com
Wed Feb 24 11:55:21 EST 2010
Karina,
You need to have your features served by a "feature server". MapServer
can do that for you. The OGC standard for that is "WFS" so you can try
to set a WFS server layer in MapServer :
http://mapserver.org/ogc/wfs_server.html
and then read it with a OpenLayers.Layer.Vector layer using a WFS
protocol :
http://openlayers.org/dev/examples/wfs-states.html
If you have trouble with the Feature Name Space property, try :
featureNS: "http://mapserver.gis.umn.edu/mapserver"
Also, don't forget to "reply-to-all" to have the MailingList aware of
our discussion. Others may want to comment too.
Kind regards,
Alexandre
Karina Guardado wrote:
> Hi,
> I reviewed the examples you gave me but I have a question. When I
> create my wms layer I provide the url and the name of the layer from
> mapserver in my mapfile like this
> var estaciones = new OpenLayers.Layer.WMS("estaciones",
> "http://myurl/cgi-bin/mapserv?MAP=/var/www/amss_wms2.map",
> {layers:'estaciones', transparent:
> "true",format:"image/gif"});
> but in the example I can see something like this
> var vectors1 = new OpenLayers.Layer.Vector("Vector Layer 1", {
> styleMap: new OpenLayers.StyleMap({
> "default": new
> OpenLayers.Style(OpenLayers.Util.applyDefaults({
> externalGraphic: "../img/marker-green.png",
> graphicOpacity: 1,
> rotation: -45,
> pointRadius: 10
> }, OpenLayers.Feature.Vector.style["default"])),
> "select": new OpenLayers.Style({
> externalGraphic: "../img/marker-blue.png"
> But I can't see where I should write the name of my layer and the url
> it is confused to me. So please if you could help me how to convert my
> wms layer into the vector layer I would really thanks a lot to you.
> karina
> On Wed, Feb 24, 2010 at 9:43 AM, Alexandre Dube <adube at mapgears.com
> <mailto:adube at mapgears.com>> wrote:
> Karina,
> Hello everybody,
> Hi
> but I would like that users could be able to click on one
> point and get the information without using this text markers.
> I found information about vector and gml layers with text
> format but I would like to know how to use them to work with
> more than one layer or if there are other solutions that
> someone could recomend.
> You're right about using Vector layers. It shouldn't matter if
> you have more than one if you use the SelectFeature control for
> feature selection. You can give it an array of Vector layers, so,
> on your map, regardless on which feature from any Vector layer,
> you should be able to select it.
> See more about this control in these examples :
> http://openlayers.org/dev/examples/select-feature-multilayer.html
> http://openlayers.org/dev/examples/select-feature-openpopup.html
> Kind regards,
> Alexandre
> thanks in advance.
> Karina Guardado
> El Salvador
> Users mailing list
> Users at openlayers.org <mailto:Users at openlayers.org>
> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com <http://www.mapgears.com>
Alexandre Dubé
Mapgears
www.mapgears.com
