Hi, if you have UMN-Mapserver installed, you can use it to generate WMS (or WFS) layers. Then you can easily add the points to your map. http://mapserver.org/input/vector/mysql.html ciao -- View this message in context: http://n2.nabble.com/mysql-database-tp4632210p4639901.html Sent from the OpenLayers Users mailing list archive at Nabble.com.
