[OpenLayers-Users] Clustering
James McManus
jmpmcmanus at gmail.com
Fri Feb 26 17:20:17 EST 2010
I was using Fixed, but BBOX did not seem to help. I'm going to take a look
at setting the threshold property higher, displaying the actual features
sooner. I was not even using the actual features, because I did not like
the way they looked. The data is a KML file which I do not have control
over, so I've been using cluster to create the actual feature.
Thanks for the suggestion.
Jim
On Fri, Feb 26, 2010 at 4:09 PM, Alexandre Dube <adube at mapgears.com> wrote:
> James,
> Have you tried the bbox strategy ?
> http://openlayers.org/dev/examples/strategy-bbox.html
> Alexandre
> James McManus wrote:
>> Hi - I'm using the cluster strategy, witch is great! However, I have
>> problems with the time it takes to render clusters for large data sets at
>> high resolution. Web browsers produce a busy or stopped responding message.
>> Is there a way I can limit the number of clusters calculated in a similar
>> way to buffering, so they will just be calculated for the display area?
>> Thanks
>> Jim
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100226/e12fae39/attachment.html
