[OpenLayers-Users] select feature control not working
Imran Rajjad
rajjad at gmail.com
Thu Jun 3 07:53:49 EDT 2010
All right and I replace the js file in geoserver directory with the
new downloaded? will that be ok?
On Thu, Jun 3, 2010 at 4:52 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> the OpenLayers versions that ship with GeoServer only include the functionality that is needed for the GeoServer layer preview. Please download a full version from http://openlayers.org
> Regards,
> Andreas.
> On Jun 3, 2010, at 13:46 , Imran Rajjad wrote:
>> thanks for your reply
>> I`m using the one that comes with geoserver 1.7.7 . not too sure about
>> the version. But the select and highlight works. When I tried the code
>> on my page.. only the highlight control was working with a highlight
>> color different from the one in example. Later through console i
>> deactivated the highlight control and then activated the select
>> control .. then the select control started working .. the events are
>> also getting triggered.i was hoping to get to the attributes of the
>> feature clicked at.
>> On Thu, Jun 3, 2010 at 4:31 PM, Eric Lemoine
>> <eric.lemoine at camptocamp.com> wrote:
>>> On Thu, Jun 3, 2010 at 12:01 PM, Imran Rajjad <rajjad at gmail.com> wrote:
>>>> I`m trying to run a function on clicking and highlighting of a vector
>>>> layer. the events do not seem to trigger..
>>>> what am i doing wrong here?
>>>> my code
>>>> var report = function(e) { // it will be called when event is trigered
>>>> from eventListeners
>>>> console.log(e.type, e.feature.id);
>>>> //alert(e.feature.id);
>>>> var highlightCtrl = new
>>>> OpenLayers.Control.SelectFeature(vector_layer, {
>>>> hover: true,
>>>> highlightOnly: true,
>>>> renderIntent: "highlight",
>>>> eventListeners: {
>>>> beforefeaturehighlighted: report,
>>>> featureunhighlighted: report
>>>> var selectCtrl = new OpenLayers.Control.SelectFeature(vector_layer,
>>>> {clickout: true}
>>>> map.addControl(highlightCtrl); // add high lighting
>>>> map.addControl(selectCtrl); // add selection
>>>> highlightCtrl.activate();
>>>> selectCtrl.activate();
>>> What OpenLayers version do you use? Does the highlight-feature.html
>>> example of your OpenLayers distribution work?
>>> Cheers,
>>> Eric Lemoine
>>> Camptocamp France SAS
>>> Savoie Technolac, BP 352
>>> 73377 Le Bourget du Lac, Cedex
>>> Tel : 00 33 4 79 44 44 96
>>> Mail : eric.lemoine at camptocamp.com
>>> http://www.camptocamp.com
>> I.R
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
I.R
