[OpenLayers-Users] Options for fighting the 180 degree problem - any server able to do it? Other approaches?
Roald de Wit R.deWit at bom.gov.au
Tue Jun 8 20:16:11 EDT 2010
Please note that GeoServer's dateline wrapping solution only works for
WMS layers. There is no official solution for vector layers yet.
At the Australian Bureau of Meteorology we are doing some work to get
around the issue (with limited success). I'd be happy to discuss our
approach and possible alternatives if there is an interest from the
community in it. Together we might tackle this problem for once and for all.
Regards, Roald
On 09/06/10 00:28, Ian Turton wrote:
> On Mon, Jun 7, 2010 at 7:04 PM, Phil Scadden<p.scadden at gns.cri.nz>  wrote:
>> Okay. I really have to get around the 180 problem.
>> Here is the issue:
>> I have line and polygon data that crosses the 180 line. Now with some
>> projections, both geoserver and ESRI ArcGIS Server can map these
>> successfully. However, the moment you want to use Google map data you
>> are in trouble. I can find no way to persuade either system to deliver
>> lines and polygon data crossing the 180 with the google spherical
>> mercator. ESRI have more or less indicated that they dont care.
>> Geoserver says it would take a rewrite of their render.
> Which was completed some time back - see
> http://blog.geoserver.org/2010/02/23/geoserver-map-wrapping/ for
> details.
> Ian
