[OpenLayers-Users] Register click event on OpenLayers.Feature.Vector
JuKiM rifins at gmail.com
Wed Jun 9 05:03:06 EDT 2010
I've seen that this is happening when I reload the layers.. For cleaning the
map and redraw other things..
if (lyrTesting) {
                lyrTesting.destroy();
            lyrTesting = new OpenLayers.Layer.Vector('Testing');
            map.addLayer(lyrTesting);
I'll investigate what is happening here..
Thanks!
2010/6/9 JuKiM <rifins at gmail.com>
> Hi,
> I'll take a look to your examples..
> But after a little searching I'm trying do like this:
> var polygonFeature = new OpenLayers.Feature.Vector(linearRing, null,
> style_poly);
> polygonFeature.data.OLPosition = position;
> polygonFeature.data.infoContent = szInformation;
> lyrTesting.addFeatures([polygonFeature]);
> var hoverSelect = new OpenLayers.Control.SelectFeature(lyrTesting, {
>         toggle: true,
>         multiple: false,
>         geometryTypes: ["OpenLayers.Geometry.LineString"],
>         renderIntent: "temporary",
>         eventListeners: {
>             featurehighlighted: function(f) {
>                 var feature = new OpenLayers.Feature(lyrTesting,
> f.feature.data.OLPosition);
>                 feature.closeBox = true;
>                 feature.popupClass = popupClass;
>                 feature.data.popupContentHTML = f.feature.data.infoContent;
>                 feature.data.overflow = (true) ? "auto" : "hidden";
>                  if (f.feature.popup == null) {
>                     f.feature.popup =
> feature.createPopup(feature.closeBox);
>                     map.addPopup(f.feature.popup);
>                     f.feature.popup.show();
>                 } else {
>                     f.feature.popup.toggle();
>             featureunhighlighted: function(f) {
>                 if (f.feature.popup != null) {
>                     f.feature.popup.destroy();
>                     f.feature.popup = undefined;
> The problem I get is when I try to redraw the map, an error is fired saying
> that there is an error with style in the next function. (Says
> that 'this.div.style' is undefined or not an object.)
> getZIndex:function(){return this.div.style.zIndex;}
> What I'm doing wrong?
> Thanks!
> 2010/6/8 giraam <sdjbm17 at gmail.com>
>> Hi,
>> Maybe you can find something useful here..
>> http://trac.openlayers.org/wiki/UserRecipes
>> http://trac.openlayers.org/wiki/UserRecipes  =)
>> Regards,
>> just another web developer
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Register-click-event-on-OpenLayers-Feature-Vector-tp5154434p5155291.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100609/27df800a/attachment.html
