[OpenLayers-Users] OPENLAYERS LayerChange
Rahn Hanno (rahn) rahn at zhaw.ch
Thu Jun 10 08:04:24 EDT 2010
Super,
That works. And how can I register a changelayer listener on the map? I try this:
var options1 = {
		maxExtent: new OpenLayers.Bounds(662642.346412,152155.850000,726497.716088,206636.150000),
		maxResolution:'auto',
		numZoomLevels: '9',
		fractionalZoom: true,
		scales: [500000, 250000, 200000, 125000, 100000, 75000, 50000, 25000, 10000],
		units: 'm',
		projection: "EPSG:21781",
		controls: []
var map = new OpenLayers.Map('map',options1,
	eventListeners: {
		"changelayer": function(e) {
        		if(e.property === "visibility") {
            		alert("visibility changed (" + e.layer.name + ")");
It doesn't work.
Thank you for your help.
Greetings
Hanno Rahn
Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche Ressourcen
Fachstelle Geoinformatik
Grüental, Postfach CH-8820 Wädenswil
Tel +41 (0)58 934 5592
Fax +41 (0)58 934 5580
hanno.rahn at zhaw.ch
www.iunr.zhaw.ch/geoinformatik
-----Ursprüngliche Nachricht-----
Von: Eric Lemoine [mailto:eric.lemoine at camptocamp.com]
Gesendet: Donnerstag, 10. Juni 2010 13:47
An: Rahn Hanno (rahn)
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] OPENLAYERS LayerChange
On Thu, Jun 10, 2010 at 1:40 PM, Rahn Hanno (rahn) <rahn at zhaw.ch> wrote:
> Hi,
> I try to make it, but it doesn't work. My layer looks like this:
> var zielrichtung = new OpenLayers.Layer.WMS("Zielrichtung",urlArray,
> {map:mapFile,layers:layerName,format:"image/png",EXCEPTIONS:"applicati
> on/vnd.ogc.se_inimage"},
>                         {singleTile: true, ratio:1},
>                         "visibilitychanged": function() {
>                                         alert("visibility changed");
> zielrichtung.setIsBaseLayer(false);
> map.addLayer(zielrichtung);
> zielrichtung.setVisibility(false);
> var sld_zRichtung = url_ziel+"indikator="+indikator1;
> zielrichtung.mergeNewParams({SLD:sld_zRichtung});
> But it doesn't work. But where is my mistake. I don't know what to do now.
> Please can somebody give me a tip?
Try this:
{map:mapFile,layers:layerName,format:"image/png",EXCEPTIONS:"application/vnd.ogc.se_inimage"},
                        {singleTile: true, ratio:1, eventListeners: {
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
