[OpenLayers-Users] OPENLAYERS LayerChange
Rahn Hanno (rahn)
rahn at zhaw.ch
Thu Jun 10 08:32:07 EDT 2010
That's it.
Thank you very much for your help.
Greetings
Hanno
Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche Ressourcen
Fachstelle Geoinformatik
Grüental, Postfach CH-8820 Wädenswil
Tel +41 (0)58 934 5592
Fax +41 (0)58 934 5580
hanno.rahn at zhaw.ch
www.iunr.zhaw.ch/geoinformatik
-----Ursprüngliche Nachricht-----
Von: Eric Lemoine [mailto:eric.lemoine at camptocamp.com]
Gesendet: Donnerstag, 10. Juni 2010 14:12
An: Rahn Hanno (rahn)
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] OPENLAYERS LayerChange
On Thu, Jun 10, 2010 at 2:04 PM, Rahn Hanno (rahn) <rahn at zhaw.ch> wrote:
> Super,
> That works. And how can I register a changelayer listener on the map? I try this:
> var options1 = {
> maxExtent: new
> OpenLayers.Bounds(662642.346412,152155.850000,726497.716088,206636.150
> 000),
> maxResolution:'auto',
> numZoomLevels: '9',
> fractionalZoom: true,
> scales: [500000, 250000, 200000, 125000, 100000, 75000,
> 50000, 25000, 10000],
> units: 'm',
> projection: "EPSG:21781",
> controls: []
> var map = new OpenLayers.Map('map',options1,
> eventListeners: {
> "changelayer": function(e) {
> if(e.property === "visibility") {
> alert("visibility changed (" + e.layer.name +
> It doesn't work.
eventListeners must be set in the map options
new OpenLayers.Map('map', {
eventListeners: {
alert("visibility changed (" + e.layer.name + ")");
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
