[OpenLayers-Users] Proj4 and displayProjection?
Zoran Jankovic zoran.m.jankovic at gmail.com
Thu Jun 10 14:13:47 EDT 2010
That's it!!!
And the solution was under my nose!
Well, that's almost it - it works now with FF and Chrome, but with IE8 it
works only in "compatibility mode". That's with proj4js-compressed.
Thanks a bunch, I owe you a beer!
New link, still be live for some time if someone has a followup...
http://89.164.44.84/geoserver/kutina/pretrazivanje_po_ulicama_vanjski_7.html
still looking for advice/links/tips on building the "search by address" web
app.
Best regards,
Zoran Jankovic
ZIS-Izrada softvera i savjetovanje / ZIS - Software Development and
Consulting
http://www.zisis.hr
M: 00 385 98 682 902
T:  00 385 44 683 374
A. Senoe 4
44320 Kutina
Croatia
On Thu, Jun 10, 2010 at 7:45 PM, Mike Adair <madair at dmsolutions.ca> wrote:
> Zoran,
> It looks like you are using Proj4js where it dynamically loads the required
> projection code files.  In some earlier versions of Proj4js that had
> problems in IE (possibly in Chrome as well) but I think that is fixed in the
> latest version.  In any case, you can get around the issue by using
> proj4js-compressed.js rather than proj4js.js which includes all projection
> code.  You can also build your own version of Proj4js-compressed with only
> the projections you need and it would save a little space.
> Mike
> Zoran Jankovic wrote:
>> Hi list,
>> I'm sort of a newbie, and I have a question regarding the usage of
>> Proj4.js, defining displayProjection and various browser interpretation. In
>> short, everything works as intended when using latest Firefox, but it seems
>> that my custom displayProjection is not recognized when using Chrome or IE8.
>> I have defined both SphericalMercator and my custom projection using
>> Proj4js.defs. I do not not for sure that this is necessary, but I have found
>> that retrieving selected data via WFS displays as I want only using this
>> setup, and only using Firefox. So FF displays data correctl on the first
>> load, you can choose Street name and click on "Display" button, and voila,
>> the map zooms to the streets BBOX. IE8 and Chrome show initial ma extent
>> somewhere in Turkmenistan, bounds are not transformed/projected correctly
>> and you can only see GMaps, not my data that is several thousand km west
>> My problem is, if I have to point it out by now, that I really need to
>> make it work at least with IE8 :-(.
>> Perhaps it is best that you should look at the example. The site is not
>> live, so I set up a little port forwarding... Please, do not abuse :-). The
>> site is in Croatian, yes I know the encoding is screwed, but this is all ad
>> hoc, just to solve this projection problem.
>> It is intended to be used for searching street names, and later on for
>> addresses as well, maybe we'll add some POI with pictures (pop up), etc. If
>> anyone has experience with this sort of things, I would very much appreciate
>> all the help, tips and/or links.
>> http://89.164.44.84/geoserver/kutina/pretrazivanje_po_ulicama_vanjski_4.html
>> The link will be live for a couple of hours... Try it with FF, and then
>> with Chrome or IE8 and you'll see what my problem is :-(.
>> Zoran Jankovic
>> Consulting
>> http://www.zisis.hr
>> A. Senoe 4
>> 44320 Kutina
>> Croatia
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>  Michael Adair
>  Senior Software Architect
>  DM Solutions Group Inc.
>  Office: (613) 565-5056 x26
>  http://www.dmsolutions.ca
>  http://research.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100610/8e5369b0/attachment.html
