[OpenLayers-Users] Problem with OpenLayers.Protocol.WFS from Geoserver
Bartłomiej Burkot pomiarowiec10 at poczta.onet.pl
Fri Jun 11 09:00:43 EDT 2010
> *Von:* Bartłomiej Burkot <pomiarowiec10 at poczta.onet.pl>
> *An:* users at openlayers.org
> *Gesendet:* Freitag, den 11. Juni 2010, 11:12:53 Uhr
> *Betreff:* [OpenLayers-Users] Problem with OpenLayers.Protocol.WFS
> from Geoserver
> Dear users
> Can somebody tell me why is the vectorlayer: "WFS stops from protocol
> WFS" in this examle not displaying?
> http://mapakrakow.pl/~bbarni/mk4/index2.php
> <http://mapakrakow.pl/%7Ebbarni/mk4/index2.php>
> I defined 2 Vector layers both from geoserver:
> First as "OpenLayers.Layer.WFS" the sercond as "OpenLayers.Layer.Vector"
> with "OpenLayers.Protocol.WFS".
> As I can see in firebug the respond from geoserver is the same GML-file
> at both Layers but at "protocol.WFS" the stops are not displaying in the
> map.
> I tryed change the version of protocol, strategy, stylemap, add the
> geoserver url to proxy.cgi and nothing helped.
> Under is my code.
> Can somebody explain me what I'm doing wrong? How to change
> OpenLayers.Protocol.WFS to request the goeserver with GET method instead
> of POST?
> Thanks
> Bartek
> wfs = new OpenLayers.Layer.WFS(  "WFS from Layer.WFS",
> "http://mapakrakow.pl:8080/geoserver/wfs",
>                     {typename: 'komunikacja:przystanki_mk'},
>                         typename: "komunikacja:przystanki_mk"
> var przystanki_wfs = new OpenLayers.Layer.Vector("WFS stops from
> protocol WFS", {
>                         strategies: [new OpenLayers.Strategy.BBOX()],
>                         //strategies: [new OpenLayers.Strategy.Fixed()],
>                           projection: new
> OpenLayers.Projection("EPSG:2180"),
>                         styleMap: styleMap1,
>                         protocol: new OpenLayers.Protocol.WFS({
>                             version: "1.0.0",
>                             srsName: "EPSG:2180",
>                             url:
>                             featureNS: "komunikacja", //featureNS:
> "komunikacja",
>                             //featureNS:
> "http://localhost:8080/komunikacja", //featureNS: "komunikacja",
> "http://mapakrakow.pl:8080/komunikacja"
>                             featureType: "przystanki_mk",
>                             geometryName: "the_geom",
>                             featurePrefix:"komunikacja",
>                             extractAttributes: false
> //schema:"http://mapakrakow.pl:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=komunikacja:przystanki_mk
> <http://mapakrakow.pl:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=komunikacja:przystanki_mk>"
> Users mailing list
> Users at openlayers.org <mailto:Users at openlayers.org>
> http://openlayers.org/mailman/listinfo/users
> Hi,
> AFAIK you have to use featureNS with original namespace and not the
> short one and WFS can´t do GET (but I´m not sure of this one).
> HTH
> best regards
> Sarah
When I change featureNS to
featureNS: "http://mapakrakow.pl:8080/komunikacja"
I get the error from firebug:
|Could not locate {http://mapakrakow.pl:8080/komunikacja}przystanki_mk in catalog.|
I cannt find the featureNS parameter in my Geoserver configuration. My
layer is defined in geoserver in workspace "komunikacja", layername is
przystanki_mk, EPSG is 2180. Geoserver has correctly computed Bounding
Boxes from data. Geometry columns name is the_geom, type: Point.
Geoserver has generated layer preview:
http://mapakrakow.pl:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=komunikacja:przystanki_mk&styles=&bbox=545448.688,226900.375,586247.75,261943.359&width=512&height=439&srs=EPSG:2180&format=application/openlayers
 From where should I read the featureNS?
My GML file (respond from geoserver WFS) generated as
OpenLayers.Layer.WFS works correctly and looks like:
|<?xml version="1.0" encoding="UTF-8"?>
<wfs:FeatureCollection xmlns="http://www.opengis.net/wfs"
xmlns||:wfs="http://www.opengis.net/wfs"
xmlns:komunikacja="http://localhost:8080/komunikacja"
xmlns:gml="http||://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http||://localhost:8080/komunikacja http://mapakrakow.pl:8080/geoserver/wfs?service=WFS&amp;version=1.0.0&amp||;request=DescribeFeatureType&amp;typeName=komunikacja%3Aprzystanki_mk http://www.opengis.net/wfs http||://mapakrakow.pl:8080/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd">
<gml:boundedBy><gml:null>unknown</gml||:null></gml:boundedBy>
<gml:featureMember><komunikacja:przystanki_mk fid="przystanki_mk.1195">
	<komunikacja||:name>N.M.P.</komunikacja:name>
	<komunikacja:idkomunika>180</komunikacja:idkomunika>
	<komunikacja:a_t>a||</komunikacja:a_t>
	<komunikacja:the_geom><gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#2180"||>
		<gml:coordinates xmlns:gml="http://www.opengis.net/gml" decimal="." cs="," ts=" ">573280.14256993,244164||.45815782</gml:coordinates>
		</gml:Point></komunikacja:the_geom>
	<komunikacja:klucz>n.m.p.</komunikacja||:klucz></komunikacja:przystanki_mk>
</gml:featureMember><gml:featureMember><komunikacja:przystanki_mk||  fid="przystanki_mk.1257">
	<komunikacja:name>M1 Nowohucka</komunikacja:name>
	<komunikacja:idkomunika>114||</komunikacja:idkomunika>
	<komunikacja:a_t>a</komunikacja:a_t>
	<komunikacja:the_geom><gml:Point srsName||="http://www.opengis.net/gml/srs/epsg.xml#2180">
		<gml:coordinates xmlns:gml="http://www.opengis.net/gml"||  decimal="." cs="," ts=" ">571810.60532311,244521.74814857</gml:coordinates>
		</gml:Point></komunikacja||:the_geom>
	<komunikacja:klucz>m1 nowohucka</komunikacja:klucz></komunikacja:przystanki_mk>
</wfs:FeatureCollection||>
Thanks for Your suggestions
Bartek
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100611/b84b2ff6/attachment.html
