[OpenLayers-Users] problem consuming escaped single quotes in GeoJSON with a clustered vector layer
Eric Lemoine eric.lemoine at camptocamp.com
Fri Jun 11 14:54:32 EDT 2010
On Fri, Jun 11, 2010 at 2:34 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> Hi Eric,
> thanks for trying that.
> I have created a cut down test case which demonstrates the problem
> http://mapguide-central.ennoble.com.au/testcase/geo_json_escaping/testcase.html
> there are two vector layers, one which is escaped and one which isn't
> the escaped one is on by default and doesn't render
Ok.
But why are you escaping quotes? From my understanding you should not,
only certain characters can escaped (with "\"), and the quote
character isn't one of them. See <http://json.org>.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
