[OpenLayers-Users] Perhaps a UMN Question
adams adams at terrestris.de
Mon Jun 14 05:55:55 EDT 2010
Hanno,
looks like your filter
EXPRESSION ''
leads to no objects for this layer,I guess : Now your filter looks for
all objects with the value '' in the column 'bfs'.
Try
EXPRESSION /./
for as single class layer first, to ensure that your filter gets some
objetcs.
...and indeed: Its a question to put better on the mapserver-list,
regards, Till
Rahn Hanno (rahn) wrote:
> Hello list,
> I have a little question. Perhaps it is a UMN Mapserver Mapfile
> question, but perhaps you can help me a little bit.
> I try to show a WMS layer in OpenLayers. For this I made a mapfile. In
> this mapfile I realise a layer like this:
> LAYER
>     NAME 'symbol'
>     TYPE POLYGON
>     CONNECTIONTYPE postgis
>     CONNECTION 'host=*** user=*** password=*** dbname=***'
>     DATA 'the_geom FROM gines_geo_2007 using unique oid using srid 21781'
>         METADATA
>                 "wms_title" "WMS symbol"
>         END
>         PROJECTION
>                 "init=epsg:21781"
>         END
>     STATUS ON
>     CLASSITEM 'bfs'
>     CLASS
>       NAME ''
>       EXPRESSION ''
>       STYLE
>         SYMBOL 0
>         SIZE 3
>                 COLOR 63 153 94
>         OUTLINECOLOR 170 85 0
>        END
>     END
> END
> All other layers in this mapfile works, so I think the mapfile header
> is correct.
> And now I try to test the layer in my OpenLayers. For this I try this:
> var urlArray =["http://***/cgi-bin/mapserv.exe?",
> "_http://***/cgi-bin/mapserv.exe?_"];
> var mapFile2 = "../htdocs/"+pfad+"/Maps/Hintergrund.map";
> var symbolLayer = new OpenLayers.Layer.WMS("Symbollayer", urlArray,
> {map:mapFile2, layers:"symbol", transparent:"true"},{singleTile: true,
> ratio:1});
> symbolLayer.setIsBaseLayer(false);
> map.addLayer(symbolLayer);
> But I see nothing. In The Layerswitcher the layer is shown, but I see
> no map. All other layers work, so that I think the extent and so on is
> right. I think this is a UMN problem, but perhaps somebody has an idea
> here? If I try to show the GetMap request directly in the Browser it
> does'nt work, but I get no error message or message that something is
> wrong.
> Hope that somebody can help me.
> Greetings
> Hanno
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100614/ad28b4b5/attachment.html
