[OpenLayers-Users] problem consuming escaped single quotes in
GeoJSON with a clustered vector layer
Zac Spitzer
zac.spitzer at gmail.com
Mon Jun 14 08:43:25 EDT 2010
yup, i was using coldfusion's built in javascript escaping format,
jsstringformat
i have found an appropriate function for json encoding option on cflib.org
thanks for you help
On 14 June 2010 17:42, Moataz Elmasry <zaza1851983ml at googlemail.com> wrote:
> I just tried your string with an online parser:
> http://json.parser.online.fr/ and eval() returned an error.
> You don't need to escape the single quote character since its inside a
> double quote, so just remove the slash \ and it should work
> Eric Lemoine wrote:
>> On Fri, Jun 11, 2010 at 2:34 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>> Hi Eric,
>>> thanks for trying that.
>>> I have created a cut down test case which demonstrates the problem
>>> http://mapguide-central.ennoble.com.au/testcase/geo_json_escaping/testcase.html
>>> there are two vector layers, one which is escaped and one which isn't
>>> the escaped one is on by default and doesn't render
>> Ok.
>> But why are you escaping quotes? From my understanding you should not,
>> only certain characters can escaped (with "\"), and the quote
>> character isn't one of them. See <http://json.org>.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
