[OpenLayers-Users] WMS layering onto OSM problems (some tiles show, others don't)
Jefferson Heard jefferson.r.heard at gmail.com
Wed Jun 16 14:29:13 EDT 2010
Thanks!!!  That worked, plus adding a displayProjection parameter.
On Jun 16, 2010, at 1:31 PM, <christopher.schmidt at nokia.com> <christopher.schmidt at nokia.com> wrote:
> On Jun 16, 2010, at 1:26 PM, ext Jefferson Heard wrote:
>> Well, the problem that I thought I had turns out not to be the case.  Yes, the requests are being made with the right projection.  No problems there.
>> The problem is that the tiles aren't being layered in, or at least not all of them.  I start with a fully zoomed out, 256x256 single tile of all of OSM, and I can see the layering there.  The next zoom in as well.  The third zoom level, I get the data layered into the tile that includes the eastern seaboard, britain, and bits of western europe, and I only get that tile.  Zooming beyond that, none of the tiles show up.
>> Using the GeoServer layer preview, reprojecting the bounding box, and asking for SRS EPSG:900913, I get all the tiles like I expect them.  I'm not sure what's different about the request I'm making in my application rather than in the GeoServer layer preview.
> I bet you don't have a maxExtent on your map.
> OL.Map("map", {
> maxExtent: new OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34)
> Should help.
>> -- Jeff
>> On Jun 16, 2010, at 1:12 PM, Ian Turton wrote:
>>> On Wed, Jun 16, 2010 at 12:00 PM, Jefferson Heard
>>> <jefferson.r.heard at gmail.com> wrote:
>>>> Right, but GeoServer can; those servers can reproject my tiles for me, but I can't seem to figure out how to adjust the WMS request that OpenLayers is making.
>>> If you set your map projection correctly then all the WMS requests
>>> will use that projection by default. No further intervention should be
>>> necessary on your part.
>>> From your original mail though it isn't obvious which layers are on GeoServer?
>>> Ian
>>> Ian Turton
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Regards,
> Christopher Schmidt
> Nokia
