[OpenLayers-Users] animated markers
Vito Tafuni vitotafuni at gmail.com
Thu Jun 17 12:47:00 EDT 2010
here you can see what i've done
http://img215.imageshack.us/img215/5382/schermatazy.png
the markers are vector graphics put into the Renderer object as i've
explained in the previous email
pointRadius is used to zoom the marker
while the info popup is centered into it
just a bit coding is needed but OpenLayers seems to be very solid!
 every opinion or suggestion is welcome!
-Vito-
Tafuni Vito
vito at vitotafuni.com
"Verba volant, scripta manent... data corrupted"
2010/6/16 Vito Tafuni <vitotafuni at gmail.com>
> hi Carlo
> i'm working on vector layer because it seems to be the right solution.
> at the moment i'm drawing a custom (vector) marker and the next step will
> be to find a way to animate it (and to show the popup window inside it).
> this is the initial code i've wrote to draw a shape on a map
>                     var point = e.xy;
>                     var markerTemplate = [
>                         point,
>                         point.offset(new OpenLayers.Pixel(100,0)),
>                         point.offset(new OpenLayers.Pixel(100,100)),
>                         point
>                     for(i=0; i<markerTemplate.length; i++){
>                         markerTemplate[i] =
> map.getLonLatFromViewPortPx(markerTemplate[i]);
>                         markerTemplate[i] = new
> OpenLayers.Geometry.Point(markerTemplate[i].lon,markerTemplate[i].lat);
>                     var style_mark = OpenLayers.Util.extend({},
> OpenLayers.Feature.Vector.style['default']);
>                     style_mark.graphicWidth = 24;
>                     style_mark.graphicHeight = 20;
>                     style_mark.graphicXOffset = 10; // default is
> -(style_mark.graphicWidth/2);
>                     style_mark.graphicYOffset = -style_mark.graphicHeight;
>                     // graphicTitle only works in Firefox and Internet
> Explorer
>                     style_mark.graphicTitle = "this is a test tooltip";
>                     var feature = new OpenLayers.Feature.Vector(new
> OpenLayers.Geometry.Polygon(new
> OpenLayers.Geometry.LinearRing(markerTemplate)),null,style_mark);
> but i've changed it with this
>                    OpenLayers.Renderer.symbol.marker = [0,0, 0,-100,
> 100,-100, 0,0];
>                    style_mark.graphicName='marker';
>                    style_mark.pointRadius=10;
>                    var point = map.getLonLatFromViewPortPx(e.xy);
> OpenLayers.Geometry.Point(point.lon,point.lat),null,style_mark);
> because i wanted a fixed size marker  respect to the zoom level of the map
> if someone know how to animate the mark (i've seen a Tween class but i had
> no time to experiment!) please write down a link or a sample code!!
> Vito
> Tafuni Vito
> 2010/6/15 Carlo Sassani <carlo at sarmoung.it>
>     Vito Tafuni <vitotafuni at ...> writes:
>     > hi to all I would like to make a marker like the "image markers" on
>     london2012http://www.london2012.com/map.php
>     > click on "Olimpic Park"so i would like to have a "zooming" animation
> on a
>     marker instead of the info bubble popup
>     > do you suggest me to work on markers layout (extending the Marker
> class) or
>     > with the vector layout (and vector shapes)??thanks Vito
>     > _______________________________________________
>     > Users mailing list
>     > Users at ...
>     > http://openlayers.org/mailman/listinfo/users
>     I've a similar problem!
>     Did you find any solution?
>     Users mailing list
>     Users at openlayers.org
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100617/a200a400/attachment.html
