[OpenLayers-Users] projection transform, not working on first load?
Ken Sanderson ken at rockies.ca
Tue Jun 22 07:42:23 EDT 2010
So I am using a few transforms with my openlayers mapping application.
Generally speaking it works fine, however it seems to never transform
properly when the application first loads.
So for example I have a database with EPSG:26911 points in it. I create
a point with those coordinates, then transform them to 900913 before
adding them as a feature to a vector layer.
Points will not show up, but if I put alert(point.x); then I will see
that the very first point will give me the UTM coordinate, but then
after that they will all be transformed appropriately and they will
display on the map and the alert gives me the web Mercator coordinate.
Without the alert though it doesnt 'trigger' it to work properly and
none of the points will be displayed.
Here is what I mean for my point feature.
var point = new
OpenLayers.Geometry.Point('.$row['place_e'].','.$row['place_n'].');
point.transform(new OpenLayers.Projection("EPSG:26911"), new
OpenLayers.Projection("EPSG:900913"));
//alert(point.x);
var pointFeature = new OpenLayers.Feature.Vector(point);
pointFeature.attributes = {icon: "./logo_icon_square.png", placeid:
"'.$row['place_id'].'"};
datapoints.addFeatures([pointFeature]);
I have found this same problem when tranforming the bounds object of my
map. If I have a click function that gives me the map coordinates, the
very first click is always the pre-tranform coordinate, after that it
functions fine.
Is there a trick to this that I am missing?
Thanks.
Ken
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
