[OpenLayers-Users] parsing a GML file into different layers
Alex Brandsen
alex.brandsen at gmail.com
Wed Jun 30 04:39:35 EDT 2010
Thank you so much Arnd, that works perfectly!
Still need to tweak it a bit, but that shouldn't be too difficult.
Thanks again,
Alex.
On Tue, Jun 29, 2010 at 9:35 PM, Arnd Wippermann <arnd.wippermann at web.de>wrote:
> Hi Alex,
> that's how I would do it. Use an Ajax request to get the GML-file and then
> parse it and add every feature to an new vector layer.
> If your GML-file residents on the same server (use relative path to the
> gml), then you don't need a proxy script.
> If have tested the below code locally with the example
> "spherical-mercator.html".
> var formats = {
> wkt: new OpenLayers.Format.WKT(),
> geojson: new OpenLayers.Format.GeoJSON(),
> georss: new OpenLayers.Format.GeoRSS(),
> gml: new OpenLayers.Format.GML(),
> kml: new OpenLayers.Format.KML()
> function getGML()
> theUrl = "/OLClient/some.gml";
> var myAjax = new OpenLayers.Ajax.Request(
> theUrl,
> method: 'get',
> onComplete: showResponse,
> onFailure: showResponseFailure
> var arr = [];
> function showResponse(response)
> var theParser = formats["gml"];
> theParser.internalProjection = null;
> theParser.externalProjection = null;
> theParser.extractStyles = false;
> theParser.extractAttributes = true;
> var features = theParser.read(response.responseText);
> if(features)
> if(features.constructor != Array)
> features = [features];
> //iterate the features and put them on a vector layer
> for(var i=0;i<features.length;i++)
> //get the feature type
> var ftType =
> features[i].geometry.CLASS_NAME.replace(/OpenLayers.Geometry./,"");
> //count the feature of a type
> arr[ftType] = arr[ftType] + 1;
> var ftLyr = new OpenLayers.Layer.Vector(ftType + " " +
> arr[ftType]);
> map.addLayer(ftLyr);
> ftLyr.addFeatures(features[i]);
> //to zoom to the features
> var bounds = features[0].geometry.getBounds().clone();
> for(var i=1;i<features.length;i++)
> bounds.extend(features[i].geometry.getBounds());
> map.zoomToExtent(bounds,false);
> else
> alert('Bad input ' + type);
> function showResponseFailure(response)
> alert(response);
> getGML();
> Arnd
> ________________________________
> Von: Alex Brandsen [mailto:alex.brandsen at gmail.com]
> Gesendet: Dienstag, 29. Juni 2010 12:23
> An: Arnd Wippermann
> Cc: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] parsing a GML file into different layers
> Hi Arnd,
> thanks for your reply, this seems like it should work. I've been trying it
> out, but can't get it to work.. What should go in the brackets after 'GML',
> and where does 'response' come from? Sorry if these are really basic
> questions, but I don't have much experience in JS or OL...
> Thanks again,
> Alex.
> On Sun, Jun 27, 2010 at 2:44 PM, Arnd Wippermann <arnd.wippermann at web.de>
> wrote:
> Hi,
> something like this should work:
> var features = new OpenLayers.Format.GML().read(response);
> if(features)
> var ftLyr = new OpenLayers.Layer.Vector("Feature " + i);
> addLayer(ftLyr);
> Arnd
> Von: users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org] Im Auftrag von Alex Brandsen
> Gesendet: Sonntag, 27. Juni 2010 14:43
> An: Eric Lemoine
> layers
> Hi Eric,
> thanks for your reply. I probably need to use OpenLayers.
> Format.GML.read() , but how do I then split the array it returns into
> different layers?
> Thanks,
> Alex.
> On Sat, Jun 26, 2010 at 7:12 AM, Eric Lemoine
> <eric.lemoine at camptocamp.com> wrote:
> On Friday, June 25, 2010, Alex Brandsen
> <alex.brandsen at gmail.com> wrote:
> > Hi all,
> > I'm building a map of a medieval wallpainting, and the
> graffiti inscribed in this wall, which can be found on
> www.thomasav.com/DurhamGraffiti/ (still quite buggy though!).
> > I was wondering if there is a way for OpenLayers to
> dynamically turn features from a single GML file into seperate layers, by
> providing an array of feature id's. I've been looking through the
> documentation and been googling around, but I can't seem to find anything
> useful. Perhaps "OpenLayers. Filter. FeatureId" could do something like
> this, but the documentation on this is quite sparse..
> > Ofcourse, I could just write a php script that would
> pre-parse the gml into seperate, temporary gml files, but I think using
> OpenLayers itself would be preferable.
> > If anyone has any ideas, I would be very grateful!
> Hi
> The protocol or format that you use will give you an array
> of
> features. You are then free to dispatch the features to
> separate
> vector layers, for example based on their ids.
> I hope it helps,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100630/6d9128da/attachment.html
