[OpenLayers-Users] Map isn't shown in IE
Andrew Cant
acant at alumni.uwaterloo.ca
Thu Mar 25 01:38:39 EDT 2010
This may be a silly question...but when you said that IE did not give
you any errors do you have the script debugging option turned on?
IE will fail JavaScript mostly silently without that turned on.
Andrew
On Wed, Mar 24, 2010 at 4:03 AM, luke82 <lukas.baehler at fhnw.ch> wrote:
> Hi List
> We set up a OL-app including a WMS as baselayer and some KML-overlays by the
> following code:
> var map;
> var select;
> var lon = 7.825916722;
> var lat = 47.58665024;
> var zoom = 6;
> var pinsKml =
> 'de/mein-profil/kalenderuebersicht.html?type=465&tx_cabagsteps_pi4%5Bteam%5D=1&cHash=84af82daadca27666768e7fb8061e4e3';
> var etappenKml = 'typo3conf/ext/cabag_steps/Resources/Public/KML/e3.kml';
> var sponsorsKml =
> "typo3conf/ext/cabag_steps/Resources/Public/KML/schrittauftrittsponsors.kml";
> document.observe("dom:loaded", init);
> function init(){
> var options = {
> controls: [new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.PanZoomBar()],
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> numZoomLevels: 7,
> scales: [10000, 20000, 50000, 100000, 200000, 500000, 1500000],
> maxScale: 10000,
> minScale: 1500000,
> maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
> 20037508.34, 20037508.34)
> map = new OpenLayers.Map('map', options);
> if (isNaN(map.size.w) || isNaN(map.size.h)) {
> map.updateSize();
> // Swisstopo-Layer
> var swisstopo = new OpenLayers.Layer.WMS( "Swisstopo",
> "http://prod.swisstopogeodata.ch/wms-fhnw", {layers: 'WMS-FHNW'} );
> // Pins-Layer
> var pins = new OpenLayers.Layer.GML("Teilnehmer", pinsKml,{
> projection: map.displayProjection,
> format: OpenLayers.Format.KML,
> formatOptions: {
> extractStyles: true,
> extractAttributes: true,
> maxDepth: 2
> // Etappen-Layer
> var etappen = new OpenLayers.Layer.GML("Route", etappenKml,{
> formatOptions: {
> maxDepth: 2
> // Sponsor-Layer
> var sponsoren = new OpenLayers.Layer.GML("Sponsoren", sponsorsKml,{
> formatOptions: {
> maxDepth: 2
> map.addLayers([swisstopo, etappen, pins, sponsoren]);
> select = new OpenLayers.Control.SelectFeature([etappen, pins, sponsoren]);
> pins.events.on({
> "featureselected": onFeatureSelect,
> "featureunselected": onFeatureUnselect
> sponsoren.events.on({
> map.addControl(select);
> select.activate();
> var point = new OpenLayers.LonLat(lon,lat);
> map.setCenter(point.transform(map.displayProjection,
> map.getProjectionObject()), zoom);
> var LayerSwitcher = new
> OpenLayers.Control.LayerSwitcher();//{'activeColor': "darkblue",
> 'fontColor': "black"}
> map.addControl(LayerSwitcher);
> function onPopupClose(evt) {
> select.unselectAll();
> function onFeatureSelect(event) {
> var feature = event.feature;
> var selectedFeature = feature;
> var popup = new OpenLayers.Popup.FramedCloud("Schritt",
> feature.geometry.getBounds().getCenterLonLat(),
> new OpenLayers.Size(100,100),
> feature.attributes.description,
> null, true, onPopupClose
> feature.popup = popup;
> map.addPopup(popup);
> function onFeatureUnselect(event) {
> if(feature.popup) {
> map.removePopup(feature.popup);
> feature.popup.destroy();
> delete feature.popup;
> All works fine in FF, Opera, Safari, Chrome. But on some XP-computers we’ve
> got problems with IE (once again), especially with IE7. No map is shown, but
> the navigation-buttons are there (see ScreenShot). No error is reported in
> IE.
> We use Prototype, so the call for the init-function is made by
> document.observe("dom:loaded", init); which should be the same like
> document.onload = ...
> Or could this be a problem?
> Perhaps I’m wrong, but I think OL doesn’t need any addons (the SVG-renderer
> is used in FF and not in IE ).
> Thanks for any idea.
> Cheers!
> http://n2.nabble.com/file/n4789595/Screenprint_Karte.jpg
> View this message in context: http://n2.nabble.com/Map-isn-t-shown-in-IE-tp4789595p4789595.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
