[OpenLayers-Users] Proxy problem in GetFeatureInfo -
nosolution??
sunny74
sb.ray at hotmail.com
Sun Mar 28 12:44:13 EDT 2010
I am tryng to issue a command directly in IE for GFI like below:
http://localhost:9000/cgi-bin/mapserv.exe?map=../htdocs/shape/newwr1rec.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application/vnd.ogc.se.xml&SRS=EPSG:4326&INFO_FORMAT=text/html&Width=600&height=600
&BBOX=70.4375 17.5375 76.0625
23.1625&X=420&Y=297&QUERY_LAYERS=STATE&FEATURE_COUNT=1
But it is giving dialog box to download mapserv.exe.
What Am I doing wrong?
Can someone provide me with the correct url.
My Mapfile is as given below:
# Map file created from QGIS project file D:/QGIS/newwr.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME newwr.map
# Map image size
SIZE 600 600
UNITS dd
EXTENT 67.440106 17.379867 78.390250 25.122977
FONTSET "fonts.txt"
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 192 192 192
IMAGEQUALITY 95
IMAGETYPE gif
OUTPUTFORMAT
NAME GIF
DRIVER 'GD/gif'
MIMETYPE 'image/gif'
#IMAGEMODE PC256
EXTENSION 'gif'
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/tmp/'
# WMS server settings
METADATA
'wms_title' 'newwr.map'
'wms_feature_mime_type' 'text/plain'
'wms_onlineresource'
'http://localhost:9000/cgi-bin/mapserv?map=c:\ms4w\apache\htdocs\Shape\newwr1.map&'
'wms_srs' 'EPSG:4326'
'queryable' 'true'
'wms_proxy_auth_type' 'ntlm'
'wms_proxy_host' 'localhost'
'wms_proxy_port' '9000'
'wms_proxy_type' 'http'
'wms_proxy_username' 'subhro'
'wms_proxy_password' 'subh26'
'gml_include_items' 'all'
END
#Scale range at which web interface will operate
# Template and header/footer settings
HEADER ../templates/Demo_header.html
TEMPLATE ../templates/Demo_query_body.html
FOOTER ../templates/Demo_footer.html
# Only the template parameter is required to display a map. See
END
LAYER
NAME 'STATE'
TYPE POLYGON
DATA 'C:\ms4w\Apache\htdocs\Shape\STATE.shp'
METADATA
'wms_title' 'STATE'
END
STATUS DEFAULT
DUMP TRUE
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'STATE'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 255 255 127
END
END
END
LAYER
NAME 'RailwayStations'
TYPE POINT
DATA 'C:\ms4w\Apache\htdocs\Shape\RailwayStations.shp'
LABELITEM 'S_NAME'
METADATA
'wms_title' 'RailwayStations'
END
STATUS OFF
DUMP TRUE
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
SYMBOL 'CIRCLE'
SIZE 8
OUTLINECOLOR 0 0 0
COLOR 255 0 0
END
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT comic_sans-bold
SIZE 6
ANTIALIAS TRUE
POSITION AUTO
FORCE TRUE
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
END # end of label
END
END
#Circle symbol
SYMBOL
NAME 'CIRCLE'
TYPE ellipse
FILLED true
POINTS
1 1
END
END
END
And my JS function to call GetFeatureInfo is:
function init2() {
//OpenLayers.ProxyHost =
"http://127.0.0.1:9000/cgi-bin/proxy.cgi?url=";
map = new OpenLayers.Map('<%=map.ClientID%>');
layer = new OpenLayers.Layer.WMS("OpenLayers WMS",
"http://localhost:9000/cgi-bin/mapserv.exe?", { map:
'../htdocs/Shape/newwr1rec.map', layers: 'STATE', format: 'png' });
layer1 = new OpenLayers.Layer.WMS("Rstations",
'../htdocs/Shape/newwr1rec.map', transparent: true,layers:
'RailwayStations', format: 'png' });
map.addLayers([layer,layer1]);
//layer = new OpenLayers.Layer.WFS("OpenLayers WFS",
"http://127.0.0.1:9000/cgi-bin/mapserv.exe?map=d:/ms4w/apache/htdocs/Shape/newwr1.map",
{ typename: 'STATE', maxfeatures: 6 }, { featureClass:
OpenLayers.Feature.WFS });
///map.addLayer(layer);
map.zoomToMaxExtent();
map.setCenter(new OpenLayers.LonLat(73.25, 20.35), 6);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.events.register('click', map, function(e) {
//alert('clicked');
OpenLayers.Util.getElement('nodeList').innerHTML =
"Loading... please wait...";
var url = layer.getFullRequestString({
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/plain',
QUERY_LAYERS: "RailwayStations",
FEATURE_COUNT: 1,
WIDTH: map.size.w,
HEIGHT: map.size.h
// var msg = document.getElementById('urlmsg');
// msg.value = url;
alert(url, "getfeatureinfo",
"location=0,status=0,scrollbars=1,width=800,height=400");
//window.open(url, '', this, setHTML, setHTML);
OpenLayers.loadUrl(url, '', this, setHTML);
OpenLayers.Event.stop(e);
I am at square 1 despite all the changes I have done in map file and code.
window.open is giving the same output as stated earlier and
does not give any o/p.
Can someone help me get OpenLayers.loadUrl(url, '', this, setHTML);
working, any two formats.
I have been trying for 1 week now but without success.
PLs provide with a working solution.
View this message in context: http://n2.nabble.com/Proxy-problem-in-GetFeatureInfo-no-solution-tp4802810p4813726.html
