[OpenLayers-Users] Re: FramedPopup + Broken
Ricardo Bayley ricardo.bayley at gmail.com
Mon Apr 4 12:59:28 EDT 2011
dr & Mike thanks to both of you for your quick replies.
In fact Mike was right, I was using the wrong image
'cloud-popup-relative.png'
I also had to clear the browser´s cache.
Thanks a lot !
Ricardo
2011/4/4 Mike Leahy <mgleahy at alumni.uwaterloo.ca>
>  Hi Ricardo,
> I had this exact same problem a few months ago. In my case, the issue was
> that the image used as the background for the framed cloud bubble was the
> wrong version. I believe the correct version of the image
> 'cloud-popup-relative.png' is located in the root 'img' folder of the
> openlayers package...but I had been using my own image directory using a
> copy of the image files that sit in 'themes/default/img'. Once I replaced
> the file corresponding file, everything looked fine.
> So, maybe try and see if replacing that file solves your problem.
> Regards,
> Mike
> On April 4, 2011 11:27:24 Ricardo Bayley wrote:
> > Here goes again, sorry
> > 2011/4/4 Ricardo Bayley <ricardo.bayley at gmail.com>
> > > Here is a screenshot of what is happening.
> > > Does anyone know why is this happening ?
> > > Best regards,
> > > Ricardo
> > >> I am using the onSelect, onUnSelect. In fact Popup does "pop".
> > >> But the problem is that the popup is not displaying as it should.
> > >> Any ideas ?
> > >> 2011/4/3 dr <rykovd at gmail.com>
> > >>> If you use SelectFeature control then you should use onSelect and
> > >>> onUnselect
> > >>> methods instead onFeatureSelect and onFeatureUnelect.
> > >>> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/FramedPopup-Broken-tp6221085p623
> > >>> 4709.html Sent from the OpenLayers Users mailing list archive at
> > >>> Nabble.com. _______________________________________________
> > >>> Users mailing list
> > >>> Users at lists.osgeo.org
> > >>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110404/b2f8fa67/attachment-0001.html
