[OpenLayers-Users] KML hotSpot not working with openlayers? - OR offset an entire layer?
K Clair
kclair at pickledradish.com
Fri Apr 8 12:08:16 EDT 2011
I saw an issue from about 4 years ago that stated that only offsets
using fractions work with the hotSpot tag. However, I'm unable to get
it to work using offset in fractions.
If there is not a way to get the offset/hotspot from the KML data, is
there a way to offset an entire layer? I would like to offset markers
that are defined in a KML layer. I tried to use
OpenLayers.Layer.imageOffset but that doesn't seem to do what I want to
do.
-Kristina
On Fri, 08 Apr 2011 10:54:26 -0400, K Clair wrote:
> Hi,
> I'm trying to use the KML style tag hotSpot to offset map markers
> defined in a kml file. This does not seem to have any effect when I
> display the KML layer in OpenLayers. Does anyone know if this is
> supported in OpenLayers?
> Thanks,
> Kristina
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
