AW: [OpenLayers-Users] How can I *set* a point on the
Input-Mapvia JS
pgr1973
pgr1973 at gmx.de
Sat Apr 9 18:07:47 EDT 2011
> vectorlayer is the reference to the vectorlayer. You have to set your
> variable there. I don't know, how you have named your vectorlayer.
I didn't name it at all. Either the drupal-module has setted it, or some
OpenLayersDefault is used. Is there a way to find out, which layers
are existing on an input-map? And even if I somehow find out, how
the layer is named and how to access it: would placing a point on it
trigger the same OpenLayer-Event/Action/Behaviour, as if the user
had set the point with his mouse?
Because that's what I want to achieve: the user enters the lon/lat
into the form-fields, but the OpenLayer-Module thinks he had
entered the point by mouseklick.
Regard Paddy
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-can-I-set-a-point-on-the-Input-Map-via-JS-tp6251457p6257806.html
