[OpenLayers-Users] allow drag through div
Andreas Hocevar
ahocevar at opengeo.org
Mon Apr 11 02:09:04 EDT 2011
set the documentDrag option of the Navigation control to true: http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Control/Navigation-js.html#OpenLayers.Control.Navigation.documentDrag
Look at the example http://openlayers.org/dev/examples/document-drag.html to see how this is done.
Andreas.
var map = new OpenLayers.Map("my-map", {});
On Apr 11, 2011, at 00:13 , Paul Stanton wrote:
> Hi all,
> Sorry if this is a re-post, I can't see my posts coming through the list yet....
> I have an openlayers map and I have positioned a div to sit inside/over the map component.
> This works fine, however when dragging the map, if the mouse moves through/over the div the drag action is terminated.
> How can I avoid the drag action from terminating?
> I know this is possible because many openlayers controls do the same however I can't track down the code to enable this feature.
> thanks, p.
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> <html>
> <head>
> <script type="text/javascript" src="http://www.openlayers.org/api/OpenLayers.js"></script>
> <script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/prototype/1.7.0.0/prototype.js"></script>
> </head>
> <body>
> <div id="map" style="margin:0px; width:300px; height:200px;"></div>
> <div id="overlay" style="position:absolute; width:100px; height:75px; border:1px solid red; background-color:white; z-index:5000; text-align:center;">I want to drag through this</div>
> <script type="text/javascript">
> create map
> var map
> = new OpenLayers.Map("map", {"maxResolution":0.703125});
> map
> .addLayers([new OpenLayers.Layer.WMS("World Map", "http://labs.metacarta.com/wms-c/Basic.py?", {layers:"basic", format:"image/png"})]);
> map
> .zoomToMaxExtent();
> put div over map
> Position
> .clone($("map"), $("overlay"), {offsetLeft:100, offsetTop:62.5, setWidth:false, setHeight:false});
> </script>
> </body>
> </html>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
