[OpenLayers-Users] layer.visibility = true doesn't add checkbox
Vidal, Antoni antoni.vidal at icc.cat
Mon Apr 11 06:03:26 EDT 2011
Ivan, Xuxo
Thanks !!
Toni
-----Missatge original-----
De: igrcic at gmail.com [mailto:igrcic at gmail.com] En nom de Ivan Grcic
Enviat: lunes, 11 de abril de 2011 10:23
Per a: Vidal, Antoni
A/c: openlayers-users at lists.osgeo.org
Tema: Re: [OpenLayers-Users] layer.visibility = true doesn't add checkbox
Hola Antoni,
if available, always use setters/getters for attributes.
So using layer.setVisibility(true/false) should raise event and
layerswitcher should change accordingly.
Regards,
Ivan
On Mon, Apr 11, 2011 at 10:15 AM, Vidal, Antoni <antoni.vidal at icc.cat> wrote:
> Hello list,
> I would like to show an overlay, only when baselayer is aerial photo, not
> over baselayer topographic map.
> My code:
> map.events.register("changebaselayer", map, function(){
>                 var tpnorto = map.getLayersByName("topoorto")[0];
>                 if(map.baseLayer.name == 'Topographic'){
>                                tpnorto.visibility = "false";
>                 }else tpnorto.visibility = "true";
> I get visibility change ok, but checkbox next to overlay name (in
> layerswitcher) are not showned and I wold like to check and uncheck this
> layer to allow user to try if overlay is visible or not when they select
> aerial map.
> Any suggestion?
> Thank's in advance.
> Antoni Vidal
> Unitat d'Aplicacions SIG-WEB
> Institut Cartogràfic de Catalunya
> Parc de Montjuïc, E-08038 Barcelona
> Tel. (+34) 93 567 15 00 (ext. 3228)
> www.icc.cat
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Ivan Grcic
GeoSolutions S.A.S.
Software Engineer
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 962313
mob:   +39 328 0559267
http://www.geo-solutions.it
http://geo-solutions.blogspot.com/
http://www.youtube.com/user/GeoSolutionsIT
