AW: [OpenLayers-Users] trouble adding local kml file to OL
Arnd Wippermann
arnd.wippermann at web.de
Wed Apr 13 14:11:25 EDT 2011
if your page and kml comes from the same location like:
http://yourserver/somepage.html
http: <http://yourserver/data/somevectors.kml>
you don't need a proxy script to get the kml.
If it is so, then your script should work. The kml file (url:
"borewells.kml") is searched at the location of your page and there is no
need of a proxy script. There have to be an other reason, why you kml file
isn't displayed. Are you sure, that the coordinates in EPSG:4326 or that the
coordinates are lay in the viewport?
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Vishal
Mehta
Gesendet: Mittwoch, 13. April 2011 00:17
An: users at openlayers.org
Betreff: [OpenLayers-Users] trouble adding local kml file to OL
Hi all,
I;m having some trouble adding a kml file to openlayers. The script is at
bottom, and i've followed this thread without solving the problem:
http://osgeo-org.1803224.n2.nabble.com/adding-KML-file-td6003583.html
note that
(a) i have apache running (but no proxy host configured- i tried to do it
but it broke my web server, i'm not an expert at troubleshooting it.
(b) webserver is back on - i use it for an application with php and postgis
(which i actually want to link to an OL application)
(c) i am new to OL
1. with both the html and kml file on the webserver,
- i get only the google map displayed, no kml file displayed
- no error message
- no kml file displayed
2. with the html on local folder and kml file on webserver
- error message Access to URL denied" code" 1012
3. with both html and kml files in local folder
- same response as 1 above
- although i dont know if i shoulde be using url to point to the file in
this case
The code is below. Any help appreciated!!
Also, do i absolutely need proxy hosting or is there some way i can use my
existing webserver and working postgis as is?
Thanks,
Vishal
<html>
<head>
<title>OpenLayers Example</title>
<script src="http://openlayers.org/api/OpenLayers.js"></script>
<script src="http://maps.google.com/maps/api/js?sensor=false"></script>
</head>
<body>
<div style="width:100%; height:100%" id="map"></div>
var map = new OpenLayers.Map('map');
var googlemap = new OpenLayers.Layer.Google('Google Layer');
map.addLayer(googlemap);
map.setCenter(
new OpenLayers.LonLat(77.6, 13).transform(
new OpenLayers.Projection("EPSG:4326"),
map.getProjectionObject()
), 12);
console.log(map.getProjection());
var vector_layer = new OpenLayers.Layer.Vector('borewells',
projection: new OpenLayers.Projection('EPSG:4326'),
protocol: new OpenLayers.Protocol.HTTP({
url: "borewells.kml",
format: new OpenLayers.Format.KML({
extractAttributes: true
strategies: [new OpenLayers.Strategy.Fixed()]
//add it to the map
map.addLayer(vector_layer);
console.log('got here');
</script>
</body>
</html>
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110413/1f6d66c5/attachment.html
