[OpenLayers-Users] WMS-layer: BBOX and SRS not being detected
InterRob
rob.marjot at gmail.com
Thu Apr 21 17:36:44 EDT 2011
Dear list,
Today I set up a MapServer WMS service. The service seems to work just fine,
as I tested it with QGIS. Even the SRS is recognized automatically:
EPSG:28992 (Dutch CS).
At the bottom of this message, I copy/pasted the GetCapabilites-response.
The bit of JavaScript used to load the OpenLayers control + map + layer, is
classical:
var map, layer;
function init(){
map = new OpenLayers.Map( 'map' );
layer = new OpenLayers.Layer.WMS( "OpenLayers WMS", "
http://localhost/mapserv?map=/var/www/geo/binnenstad_wms.map&", { layers
: 'pgn_verwachting' }, { units : 'm', projection : new
OpenLayers.Projection("EPSG:28992"), singleTile : true, buffer : 0, ratio :
1 } );
In my browser, OpenLayers does load nicely (zoom and pan tools become
available in the upper right corner of an empty map-div) and then does the
following GET to fetch that single tile:
http://localhost/mapserv?map=/var/www/geo/binnenstad_wms.map&LAYERS=pgn_verwachting&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fjpeg&SRS=EPSG%3A28992&BBOX=-281.25,-210.9375,281.25,210.9375&WIDTH=800&HEIGHT=600
I don't see how I can get the BBOX parameter right... What am I missing?
When I edit the above URL, it works just fine, obviously...
And shouldn't the SRS be detected automatically as well?
Hints are much appreciated!
Kind regards,
Rob
=============== GetCapabilities response ======================
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM "
http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.1.1">
<!-- MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>OGC:WMS</Name>
<Title>Beleidskaart_Binnenstad</Title>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="
http://localhost/mapserv?map=/var/www/geo/binnenstad_wms.map&"/>
<ContactInformation>
</ContactInformation>
</Service>
<Capability>
<Request>
<GetCapabilities>
<Format>application/vnd.ogc.wms_xml</Format>
<DCPType>
<HTTP>
<Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://localhost/mapserv?map=/var/www/geo/binnenstad_wms.map&
;"/></Get>
<Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
;"/></Post>
</HTTP>
</DCPType>
</GetCapabilities>
<GetMap>
<Format>image/gif</Format>
<Format>image/png</Format>
<Format>image/png; mode=24bit</Format>
<Format>image/jpeg</Format>
<Format>image/vnd.wap.wbmp</Format>
<Format>image/tiff</Format>
<Format>image/svg+xml</Format>
<DCPType>
<HTTP>
;"/></Get>
;"/></Post>
</HTTP>
</DCPType>
</GetMap>
<GetFeatureInfo>
<Format>text/plain</Format>
<Format>application/vnd.ogc.gml</Format>
<DCPType>
<HTTP>
;"/></Get>
;"/></Post>
</HTTP>
</DCPType>
</GetFeatureInfo>
<DescribeLayer>
<Format>text/xml</Format>
<DCPType>
<HTTP>
;"/></Get>
;"/></Post>
</HTTP>
</DCPType>
</DescribeLayer>
<GetLegendGraphic>
<DCPType>
<HTTP>
;"/></Get>
;"/></Post>
</HTTP>
</DCPType>
</GetLegendGraphic>
<GetStyles>
<DCPType>
<HTTP>
;"/></Get>
;"/></Post>
</HTTP>
</DCPType>
</GetStyles>
</Request>
<Exception>
<Format>application/vnd.ogc.se_xml</Format>
<Format>application/vnd.ogc.se_inimage</Format>
<Format>application/vnd.ogc.se_blank</Format>
</Exception>
<VendorSpecificCapabilities />
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
RemoteWFS="0"/>
<Layer>
<Name>Beleidskaart_Binnenstad</Name>
<Abstract>Beleidskaart_Binnenstad</Abstract>
<SRS>EPSG:28992</SRS>
<LatLonBoundingBox minx="5.03953" miny="52.0181" maxx="5.05006"
maxy="52.0236" />
<BoundingBox SRS="EPSG:28992"
minx="131110" miny="447700" maxx="131830" maxy="448310" />
<Layer queryable="0" opaque="0" cascaded="0">
<Name>pgn_verwachting</Name>
<Title>pgn_verwachting</Title>
<LatLonBoundingBox minx="5.04025" miny="52.0182" maxx="5.04993"
maxy="52.0236" />
minx="131160" miny="447707" maxx="131821" maxy="448305"
<Style>
<Name>default</Name>
<Title>default</Title>
<LegendURL width="147" height="41">
xlink:type="simple" xlink:href="
http://localhost/mapserv?map=/var/www/geo/binnenstad_wms.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=pgn_verwachting&format=image/png&STYLE=default
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110421/59b539c3/attachment.html
