[OpenLayers-Users] Re: clustering strategy problem in 900913
projection
AlexR
alexrushforth at hotmail.com
Wed Apr 27 09:29:46 EDT 2011
Many thanks for your reply Steve
I've tried changing the distance and threshold values and i don't think that
is the problem. The same thing happens if I modify the code on the
Openlayers cluster example (full code below). As soon as I add projection
options the clustering stops working! not sure if this is a bug with OL or a
problem in my code??
can anyone see a problem here?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta name="viewport" content="width=device-width; initial-scale=1.0;
maximum-scale=1.0; user-scalable=0;" />
<meta name="apple-mobile-web-app-capable" content="yes" />
<title>OpenLayers Cluster Strategy Threshold</title>
<link rel="stylesheet"
href="http://openlayers.org/dev/theme/default/style.css" type="text/css" />
href="http://openlayers.org/dev/examples/style.css" type="text/css" />
</head>
<body onload="init()">
<div id="tags">
vector, feature, stylemap, wfs, cluster, strategy, cleanup
</div>
<p id="shortdesc">
Demonstrates the use of the cluster strategy threshold property.
</p>
<div id="map" class="smallmap"></div>
<br />
<p>Cluster details: hover over a feature to see details.</p>
<ul>
<li>
<input id="distance" name="distance" type="text" value=""
size="3" />
<label for="distance">distance</label>
</li>
<li>
<input id="threshold" name="threshold" type="text" value=""
size="3" />
<label for="threshold">threshold</label>
</li>
</ul>
<button id="reset">recluster</button>
</body>
</html>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/clustering-strategy-problem-in-900913-projection-tp6280745p6309471.html
