[OpenLayers-Users] openlayers vs mobile vs google
Gilbert, Antoine AGilbert at korem.com
Wed Apr 27 10:32:08 EDT 2011
I just started again to play around with the new mobile stuff
When I use a WMS layer on top of an OSM layer, gesture previewing work great, fluid, etc.
For Google base layer, as discussed before, there is no gesture previewing, but I add a WMS layer on top the WMS layer is previewing correctly with gesture while Google layer stay unchanged until the end of the gesture. This is ok until the related DEV will be done.
But in that case (WMS + Google), performance are slow, the WMS layer image resizing is sloppy. I wonder why. The same CSS transformation than with OSM should be applied in the same way with the same performance?
Antoine
-----Original Message-----
From: Eric Lemoine [mailto:eric.lemoine at camptocamp.com]
Sent: 8 avril 2011 14:58
To: Gilbert, Antoine
Cc: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] openlayers vs mobile vs google
On Friday, April 8, 2011, Gilbert, Antoine <AGilbert at korem.com> wrote:
> Hi I started this week to play with the openlayers trunk version in a mobile context The gesture stuff seems to work great with an OSM layer but I noticed there is no gesture previewing with a Google layer, i.e. while doing the gesture there is no interaction until the gesture is done.
Yes, this is expected. Fixed layers, i.e. layers outside the layer
container, are not scaled on pinch in/out.
> Does fully support Google layers with gesture is planned soon in DEV?
To my knowledge there's no work being currently done, but it will
certainly come sooner and later.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
