[OpenLayers-Users] Problem with configures OpenLayers.js
Marc Jansen
jansen at terrestris.de
Mon Aug 1 05:34:00 EDT 2011
Hi Satish,
setting OpenLayers.ImgPath should help.
Regards,
Marc
On 29.07.2011 00:44, sjonnala wrote:
> Hi there,
> I configured a OpenLayers.js file by removing unnecessary classes from
> version 2.10. Then started the problem. I'm unable to see the images on the
> viewport. Inorder to make my issue clear I'm including the screenshots
> below.
> With original OpenLayers.js 2.10
> http://osgeo-org.1803224.n2.nabble.com/file/n6631632/before.bmp before.bmp
> With configured OpenLayers.js 2.10
> http://osgeo-org.1803224.n2.nabble.com/file/n6631632/after.bmp after.bmp
> I'm sure this is the problem with css in associating the path to the images.
> Where in OpenLayers.js can i configure the path, for the display of the
> images to work correctly.
> Thanks & Regards
> Satish Jonnala
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-configures-OpenLayers-js-tp6631632p6631632.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
