AW: [OpenLayers-Users] WMS-C/TMS and WMTS
Andreas Hocevar ahocevar at opengeo.org
Wed Aug 3 05:37:41 EDT 2011
Yes you can. Let's say you have a typical xyz directory structure, like the Mapnik OSM tiles. Then you could create a custom XYZ layer:
new OpenLayers.Layer.XYZ({
    url: "file:///path/to/my/tiles/${z}/${x}/${y}.png"
Andreas.
On Aug 3, 2011, at 11:32 , Noli Sicad wrote:
>> it is enough to have the tiles in a folder structure on the disk. If the
>> disk is on your local machine, you can even use file urls (file://). If it's
>> on a server, the directory structure should be served by a plain HTTP server
>> (e.g. Apache).
>> If the disk is on your local machine, you can even use file urls (file://).
> Just to clarify this statement above, can use tile files without http
> or tile sever in OpenLayers?
> Any OL example for this tile files without the server?
> Thanks.
> Noli
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
