[OpenLayers-Users] Popup only on WMS layer object
Sveen Atle Frenvik (Geomatikk IKT)
Atle.Frenvik.Sveen at geomatikk.no
Wed Aug 3 08:32:14 EDT 2011
This is a bit tricky, as the wms server sends a response independent of wether it found any features or not.
A simple solution could be to check the response text for a string you know is only present if there are indeed results. (ie. geoserver adds
<table class="featureInfo"> if there are results). This can be done with someting like:
info = new OpenLayers.Control.WMSGetFeatureInfo({
url: 'http://webgis.24gis.pl/geoserver/wms',
title: 'Identify features by clicking',
queryVisible: true,
infoFormat: 'text/html',
maxFeatures: 1,
eventListeners: {
getfeatureinfo: function(event) {
if (event.text.indexOf("<table class=\"featureInfo\">") != -1){
popup = new OpenLayers.Popup.FramedCloud(
"chicken",
map.getLonLatFromPixel(event.xy),
null,
event.text,
null,
true
autoSize: false,
maxSize: new OpenLayers.Size(5,5)
map.addPopup(popup);
map.addControl(info);
On 2011-08-03 13:22, michsred wrote:
Hi list,
is it possible to construct GetFeatureInfo machanism with popup which will
be active only on objects (points, lines, polygons) from WMS layers. I
already have popups working on my whole map. When I click outside of object
e.g polygon the opened popup is empty. I would like to have popups which
apear only on objects (or more precisely, only on places where
GetFeatureInfo information is present).
This is GetFeatureInfo code which I use:
queryVisible: true,
maxFeatures: 1,
eventListeners: {
"chicken",
null,
event.text,
null,
true
autoSize: false,
Thank you in advance for any sugestion!
Michal
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Popup-only-on-WMS-layer-object-tp6648352p6648352.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Atle Frenvik Sveen
Utvikler
Geomatikk IKT AS
tlf: 45 27 86 89
atle.frenvik.sveen at geomatikk.no
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110803/df6da880/attachment.html
