[OpenLayers-Users] I want my vectors do not update their visual representation
Andreas Hocevar ahocevar at opengeo.org
Thu Aug 4 21:29:37 EDT 2011
you could try the SVG2 renderer,  by configuring your vector layer with
renderers : ["SVG2", "VML",  "Canvas"]
You will need at least OpenLayers 2.11rc1 for this to work, and it will only
work on browsers that support SVG. To work in this context means that you
will see all features as soon as they pan into view.
Andreas.
Andreas.
On Aug 4, 2011 3:07 PM, "ggarcia" <ggarcia at ihman.com> wrote:
//From the FAQ: vectors do not update their visual representation while the
map is being dragged. Instead, they update when the mouseup event fires. For
this reason, while dragging, you may occasionally see 'cut off' vector
features. I *don't want to update vectors* visual representation because
they are simple static images, I only wanna avoid the render to *avoid 'cut
off' vector features*. Could I do this using "unrenderedFeatures",
"rendererOptions" or whatever? I have 10000 markers images (vector) so every
time I drag the map all markers are repainted so it makes my webapp too
heavy and slow :S
View this message in context: I want my vectors do not update their visual
representation<http://osgeo-org.1803224.n2.nabble.com/I-want-my-vectors-do-not-update-their-visual-representation-tp6652628p6652628.html>
Sent from the OpenLayers Users mailing list
archive<http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Users-f1822463.html>at
Nabble.com.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110805/c4818b8c/attachment.html
