[OpenLayers-Users] Poll: Common pitfalls when using OpenLayers / what annoys you the most?
Marc Jansen jansen at terrestris.de
Fri Aug 5 06:46:01 EDT 2011
Hi Dave,
thanks for the feedback. I'd put your point under the following headline:
"API-doc improvements (incomplete, e.g. callback arguments missing)"
OK?
Best regards,
Marc
On 05.08.2011 12:41, Dave Potts wrote:
> Hi
> I think you might want to add the callback details as well, for an example
> look at the Savestratgy callback listed for the current level of
> documentation.  The arguments for the callbacks are not listed
> eg
> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Strategy/Save-js.html
> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Handler/Click-js.html
> The method for deleting a web feature item can only be discovered by
> reading one of the example program, even then you have to set an internal
> flag to make it work.
> I think openlayers is a very useful, but its documentation does let it
> down somewhat.
> Dave.
>> Hi Roald,
>> "API-doc improvements (ingherited methods and properties)"
>> OK?
>> Best regards,
>> Marc
>> On 05.08.2011 10:58, Roald de Wit wrote:
>>> Hi,
>>> One thing that bugs me every now and then is the API docs: they don't
>>> show inherited properties/methods for a class. Finding out what
>>> methods a class implements can be a pain.
>>> Cheers, Roald
>>> On 05/08/11 17:26, Marc Jansen wrote:
>>>> Hi all,
>>>> for my talk "Common pitfalls for users of OpenLayers" [1] at this years
>>>> FOSS4G [2] I want to evaluate the parts of OpenLayers where users of
>>>> the
>>>> library experience problems.
>>>> You would help me -- and the project itself -- a lot if you could
>>>> answer
>>>> in this thread and tell me what problems you had working with
>>>> OpenLayers.
>>>> Please do not hesitate to tell us what has bugged you, what was unclear
>>>> or non-intuitive. Provide us with the sall and the big annoyances Of
>>>> course you are heavily encouraged to provide ways around the pitfalls
>>>> and possible enhancements.
>>>> I want to identify areas which often cause problems... and eventually I
>>>> plan on making the library better where this is possible.
>>>> Anyone is invited to share his/her thoughts -- so if you want the
>>>> library to improve, go on and tell us where we can make things better.
>>>> Thanks in advance,
>>>> Marc
>>>> [1] http://2011.foss4g.org/sessions/common-pitfalls-users-openlayers
>>>> [2] http://2011.foss4g.org/
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> Users mailing list
>> Users mailing list
