[OpenLayers-Users] WFS Spatial Filter throwing Error 500
Bryan Hempen
bhempen at sciops.esa.int
Fri Aug 5 07:52:02 EDT 2011
The problem: I am trying to implement something similar to
http://openlayers.org/dev/examples/wfs-spatial-filter.html with my own
data served by MapServer through a WFS. I just changed some lines in the
code to make it work with MapServer, so the code is almost equal to the
code in the example at the moment. So far it's working fine UNTIL I drag
the polygon to apply the spatial filter! According to the
getCapabitilies the server should be able to handle the request:
<ogc:Spatial_Capabilities>
<ogc:Spatial_Operators>
<ogc:Equals/>
<ogc:Disjoint/>
<ogc:Touches/>
<ogc:Within/>
<ogc:Overlaps/>
<ogc:Crosses/>
<ogc:Intersect/>
<ogc:Contains/>
<ogc:DWithin/>
<ogc:BBOX/>
</ogc:Spatial_Operators>
</ogc:Spatial_Capabilities>
Both WFS GetFeature requests are sent via HTTP POST. The first one that
works (called on page load) looks like this:
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" xmlns:xsi="http
://www.w3.org/2001/XMLSchema-instance" service="WFS" version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd">
<wfs:Query typeName="omega">
<ogc:Filter xmlns:ogc="http://www .opengis.net/ogc">
<ogc:BBOX>
<ogc:PropertyName>msGeometry</ogc:PropertyName>
<gml:Box xmlns:gml="http: //www.opengis.net/gml" srsName="EPSG:4326">
<gml:coordinates decimal="." cs="," ts=" ">135.45,-47.425
157.95,-36.175</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
The request not working looks like this:
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" service="WFS"
version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wfs
<wfs:Query xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
typeName="ms:omega">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:And>
<ogc:Intersects>
<gml:Polygon xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">
<gml:outerBoundaryIs>
<gml:LinearRing>
">145.72880866081,-40.709423872828 145.83867194206,-42.752880904078
148.34355475456,-40.995068404078
145.72880866081,-40.709423872828</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ogc:Intersects>
<ogc:BBOX>
<gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">
<gml:coordinates decimal="." cs="," ts=" ">135.45,-47.40302734375
157.95,-36.15302734375</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:And>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
The error message I receive:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>500 Internal Server Error</title>
</head><body>
<h1>Internal Server Error</h1>
<p>The server encountered an internal error or
misconfiguration and was unable to complete
your request.</p>
<p>Please contact the server administrator,
root at localhost and inform them of the time the error occurred,
and anything you might have done that may have
caused the error.</p>
<p>More information about this error may be available
in the server error log.</p>
<hr>
<address>Apache/2.2.3 (Red Hat) Server at localhost Port 80</address>
</body></html>
Does anyone have an idea? I don't know if this is a MapServer or
OpenLayers or (whatever?) problem. Any help is appreciated, I am stuck.
The setup:
* OS: Red Hat Enterprise Linux 5.4
* PostgreSQL 8.2
* PostGIS 1.3
* MapServer 5.6.5
* OpenLayers, one of the latest versions. ProxyHost set and working
(calling the proxy.cgi leads to OpenLayers website)
Kind regards,
Bryan
This message and any attachments are intended for the use of the addressee or addressees only. The unauthorised disclosure,
use, dissemination or copying (either in whole or in part) of its content is not permitted. If you received this message in
error, please notify the sender and delete it from your system. Emails can be altered and their integrity cannot be guaranteed by
the sender.
Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110805/712f2c35/attachment.html
