[OpenLayers-Users] Re: WMS object
Julien Cigar
jcigar at ulb.ac.be
Mon Aug 8 06:45:07 EDT 2011
Normally the only thing to do is to use an "SRS" parameter, something like:
var layer = new OpenLayers.Layer.WMS(
'YOUR_LAYER_NAME', "http://YOUR_WMS_SERVER', {
layers: 'YOUR_LAYER',
transparent: true,
format: 'image/png',
SRS: 'EPSG:3857',
SLD: 'http://YOUR_SLD_ADDRESS'
isBaseLayer: false,
singleTile: true,
opacity: 0.8,
visibility: false
I don't know which WMS server you use, but if it's Mapserver don't
forget to add the supported projections in the WEB METADATA section,
something like "wms_srs" "EPSG:4326 EPSG:3857", otherwise it will not work.
For example:
WEB
IMAGEPATH "/tmp/"
IMAGEURL "/tmp/"
METADATA
"ows_enable_request" "*"
# WMS #
"wms_title" "my WMS server"
"wms_onlineresource"
"http://my/wms/address?map=/path/to/mapfile.map&"
END
END
Julien
On 08/08/2011 12:26, Jan Henrik Øverland wrote:
> How do I request a specific SRS when creating a wms layer?
> On Fri, Aug 5, 2011 at 14:22, Jan Henrik Øverland
> <janhenrik.overland at gmail.com <mailto:janhenrik.overland at gmail.com>> wrote:
> Hi, my map is EPSG:900913 and running Google Maps nicely. The
> following WMS feed is served both as EPSG:4326 and EPSG:900913 (have
> a look at the WMS link in the table):
> http://iridl.ldeo.columbia.edu/SOURCES/.USGS/.LandDAAC/.MODIS/.1km/.8day/.version_005/.Aqua/.EAF/.Night/.LST/X+Y+fig-+colors+coasts+-fig+//LST/255./330./plotrange//T/3118./plotvalue/Y/1.5405659E-04/39.99557/plotrange//plotborder+72+psdef//plotaxislength+432+psdef//XOVY+null+psdef/
> When I do this:
> var wms = new OpenLayers.Layer.WMS(
> "IRI",
> "http://iridl.ldeo.columbia.edu/SOURCES/.USGS/.LandDAAC/.MODIS/.1km/.8day/.version_005/.Aqua/.EAF/.Night/.LST/X+Y+fig-+colors+coasts+-fig+//LST/255./330./plotrange//T/3118./plotvalue/Y/1.5405659E-04/39.99557/plotrange//plotborder+72+psdef//plotaxislength+432+psdef//XOVY+null+psdef/wms.xml",
> layers: "USGS LandDAAC MODIS 1km 8day version_005 Aqua EAF
> Night LST",
> ..I get a 4326 base layer. But I want it to work with my 900913 map
> so I add to the params object:
> Night LST",
> srs: "EPSG:900913",
> bbox: "-2000000,1,6900000,4400000"
> but it does not work. The getFullRequestString() returns a string
> with the correct BBOX, but the SRS it still 4326.
> To me it looks like only the first tile has 900913 and the rest
> (twenty-something) have 4326. What am I doing wrong?
> Jan
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110808/0c02a355/jcigar.vcf
