[OpenLayers-Users] Re: WMS object
Andreas Hocevar
ahocevar at opengeo.org
Mon Aug 8 07:25:07 EDT 2011
On Aug 8, 2011, at 12:45 , Julien Cigar wrote:
> Hi,
> Normally the only thing to do is to use an "SRS" parameter, something like:
This is a common pitfall when using OpenLayers. The SRS parameter will be ignored. Always. Instead, WMS layers will be requested in the SRS used by your base layer.
Andreas.
> var layer = new OpenLayers.Layer.WMS(
> 'YOUR_LAYER_NAME', "http://YOUR_WMS_SERVER', {
> layers: 'YOUR_LAYER',
> transparent: true,
> format: 'image/png',
> SRS: 'EPSG:3857',
> SLD: 'http://YOUR_SLD_ADDRESS'
> isBaseLayer: false,
> singleTile: true,
> opacity: 0.8,
> visibility: false
> I don't know which WMS server you use, but if it's Mapserver don't forget to add the supported projections in the WEB METADATA section, something like "wms_srs" "EPSG:4326 EPSG:3857", otherwise it will not work.
> For example:
> WEB
> IMAGEPATH "/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "ows_enable_request" "*"
> # WMS #
> "wms_title" "my WMS server"
> "wms_onlineresource" "http://my/wms/address?map=/path/to/mapfile.map&"
> END
> END
> Julien
> On 08/08/2011 12:26, Jan Henrik Øverland wrote:
>> How do I request a specific SRS when creating a wms layer?
>> On Fri, Aug 5, 2011 at 14:22, Jan Henrik Øverland
>> <janhenrik.overland at gmail.com <mailto:janhenrik.overland at gmail.com>> wrote:
>> Hi, my map is EPSG:900913 and running Google Maps nicely. The
>> following WMS feed is served both as EPSG:4326 and EPSG:900913 (have
>> a look at the WMS link in the table):
>> http://iridl.ldeo.columbia.edu/SOURCES/.USGS/.LandDAAC/.MODIS/.1km/.8day/.version_005/.Aqua/.EAF/.Night/.LST/X+Y+fig-+colors+coasts+-fig+//LST/255./330./plotrange//T/3118./plotvalue/Y/1.5405659E-04/39.99557/plotrange//plotborder+72+psdef//plotaxislength+432+psdef//XOVY+null+psdef/
>> When I do this:
>> var wms = new OpenLayers.Layer.WMS(
>> "IRI",
>> "http://iridl.ldeo.columbia.edu/SOURCES/.USGS/.LandDAAC/.MODIS/.1km/.8day/.version_005/.Aqua/.EAF/.Night/.LST/X+Y+fig-+colors+coasts+-fig+//LST/255./330./plotrange//T/3118./plotvalue/Y/1.5405659E-04/39.99557/plotrange//plotborder+72+psdef//plotaxislength+432+psdef//XOVY+null+psdef/wms.xml",
>> layers: "USGS LandDAAC MODIS 1km 8day version_005 Aqua EAF
>> Night LST",
>> ..I get a 4326 base layer. But I want it to work with my 900913 map
>> so I add to the params object:
>> Night LST",
>> srs: "EPSG:900913",
>> bbox: "-2000000,1,6900000,4400000"
>> but it does not work. The getFullRequestString() returns a string
>> with the correct BBOX, but the SRS it still 4326.
>> To me it looks like only the first tile has 900913 and the rest
>> (twenty-something) have 4326. What am I doing wrong?
>> Jan
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> No trees were killed in the creation of this message.
> However, many electrons were terribly inconvenienced.
> <jcigar.vcf>_______________________________________________
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
