[OpenLayers-Users] Display geotagged photos in OpenLayers
Hendrik Oesterlin
hendrikmail2002 at yahoo.de
Tue Aug 16 07:25:17 EDT 2011
"Franz Buchinger" fbuchinger at gmail.com wrote on 16/08/2011 at 21:17:11 +1100
subject "[OpenLayers-Users] Display geotagged photos in OpenLayers" :
Thank you very much for your reply!
> first of all, you probably want to generate thumbnails of your photos and
> load these into the map instead of the large-size images you are using now.
> This gives you a much better performance.
Yes, this is very easy to do. Shrink the jpg instead of setting only
the pixel dimensions.
> The popup can then contain a link
> to the full-res version of the photo.
How can the pop up size be defined?
> Extracting EXIF/GPS metadata from JPEG images in Javascript is possible, but
> quite hacky and out of OpenLayers' scope. There is a Javascript library of
> Jacob Seidelin that does that (
> http://blog.nihilogic.dk/2008/05/reading-exif-data-with-javascript.html),
> but it comes with the downside that you have to download all hi-res versions
> of the photos to the browser in order to get the gps coordinates contained
> in the exif metadata.
> A better approach would be to dump out the GPS coordinates of the photos
> into a JSON file, and load that file into OpenLayers with an AJAX request.
> You can then specify an Openlayers.Format that parses this information and
> creates a feature for each of your photo.
As I am not a web designer, and I am not familiar enough with
JavaScript, JSON and AJAX this is not easy to achieve for me...
> You can use the exiftool command line utility (
> http://www.sno.phy.queensu.ca/~phil/exiftool/) to quickly dump out all GPS
> coordinates into a JSON structure, see the reading examples page (
> http://www.sno.phy.queensu.ca/~phil/exiftool/exiftool_pod.html#reading_examples)
> for more information.
Thank you for this tool! extracting lat/lon is easy with it and I will
be able to create the text file for use with the
var Photos = new OpenLayers.Layer.Text("Photos",{location:"data/photos.txt", projection: epsg4326});
map.addLayer(Photos);
code.
My remaining problem is to enlarge the pop up size big enough to fit
the photo in it.
An "X" to close the pop up would be handy too.
Sincerely
Hendrik Oesterlin - email hendrikmail2002 at yahoo.de
