[OpenLayers-Users] set start and end point
Stephen Woodbridge woodbri at swoodbridge.com
Tue Aug 16 14:16:50 EDT 2011
On 8/16/2011 12:04 PM, Sush Pokharel wrote:
> Hi Guys,
> I am using pgrouting + openlayers
> I am trying to set start and end point layer to pass to pgrouting. I
> tried the code from
> http://www.pgrouting.org/docs/ol-workshop/ch05.html. But i couldnot get
> the layer for start and end point. here is my code:
Do you have a copy of start.png and stop.png on you server in the same
directory as the html file???
What if any errors/symptoms are you getting? Do you have firebug
installed reload the page and wait the Net tab while you set the start
and stop points and check the console tab to see if you are getting errors.
-Steve
> <html xmlns="http://www.w3.org/1999/xhtml" >
> <head>
> <style type="text/css" >
> #map {
> width: 500px;
> height: 500px;
> border: 1px solid black;
> </style>
> <script src="openlayers/OpenLayers.js" ></script>
> <script type="text/javascript" >
> var SinglePoint = OpenLayers.Class.create();
> SinglePoint.prototype = OpenLayers.Class.inherit(OpenLayers.Handler.Point, {
> createFeature: function(evt) {
> this.control.layer.removeFeatures(this.control.layer.features);
> OpenLayers.Handler.Point.prototype.createFeature.apply(this, arguments);
> var start_style = OpenLayers.Util.applyDefaults({
> externalGraphic: "start.png",
> graphicWidth: 18,
> graphicHeight: 26,
> graphicYOffset: -26,
> graphicOpacity: 1
> }, OpenLayers.Feature.Vector.style['default']);
> var stop_style = OpenLayers.Util.applyDefaults({
> externalGraphic: "stop.png",
> graphicWidth: 18,
> graphicHeight: 26,
> graphicOpacity: 1
> var map;
> var dublin;
> var counties;
> var start;
> var stop;
> function init() {
> var bounds = new OpenLayers.Bounds(
> 297730.375, 217955.328,
> 330136.625, 260578.453
> var options = {
> controls: [new OpenLayers.Control.PanZoom() ,],
> maxExtent: bounds,
> maxResolution: 166.49658203125,
> projection: "EPSG:29900",
> units: 'm'
> map = new OpenLayers.Map('map', options);
> dublin = new OpenLayers.Layer.WMS( "dublin historical" ,
> "http://localhost:8080/geoserver/wms?" ,
> {layers: 'Ireland:buildings_geodir',transparent:true} );
> counties = new OpenLayers.Layer.WMS( "counties" ,
> {layers: 'Ireland:dublin_highway1'} );
> start = new OpenLayers.Layer.Vector("Start point", {style: start_style});
> stop = new OpenLayers.Layer.Vector("End point", {style: stop_style});
> map.addLayer(counties);
> map.addLayer(dublin);
> map.addLayer(start);
> map.addLayer(stop);
> map.addControl(new OpenLayers.Control.Navigation());
> map.addControl(new OpenLayers.Control.LayerSwitcher() );
> map.addControl(new OpenLayers.Control.MousePosition({element:
> $('location')}));
> map.zoomToExtent(bounds);
> controls = {
> start: new OpenLayers.Control.DrawFeature(start, SinglePoint),
> stop: new OpenLayers.Control.DrawFeature(stop, SinglePoint)
> for (var key in controls) {
> map.addControl(controls[key]);
> function toggleControl(element) {
> for (key in controls) {
> if (element.value == key && element.checked) {
> controls[key].activate();
> } else {
> controls[key].deactivate();
> </script>
> </head>
> <body onload="init()" >
> <div id="map" ></div>
> <li>
> <input type="radio" name="control" value="start" id="startToggle"
> onclick="toggleControl(this);" />
> <label for="startToggle">set start point</label>
> </li>
> <li>
> </li>
> </body>
> </html>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
