[OpenLayers-Users] Formatting output text
JK Chen
jk.chen at sdl.usu.edu
Wed Aug 17 18:10:26 EDT 2011
but I don't have a mouse move function.
-----Original Message-----
From: Joel Leininger [mailto:leiningr at gmail.com]
Sent: Wednesday, August 17, 2011 4:06 PM
To: JK Chen
Cc: Bart van den Eijnden; openlayers-users at lists.osgeo.org
Subject: RE: [OpenLayers-Users] Formatting output text
Well, I stuck it right after the mousemove function, and it works like a charm. I actually embellished Bart's code a bit because we have some coordinate systems with South and West values. Here is my final code:
OpenLayers.LonLat.prototype.toString = function()
if (this.lat < 0)
var ns = "S";
this.lat = Math.abs(this.lat);
else {
var ns = "N";
if (this.lon < 0)
var ew = "W";
this.lon = Math.abs(this.lon);
else {
var ew = "E";
return (ns + " " + this.lat.toFixed() + ", " + ew + " " + this.lon.toFixed());
(Watch the wrap in the email on the last line.)
Add number of digits desired in the toFixed(##) function.
Thanks again, Bart. The results look great.
-J.
On Wed, 2011-08-17 at 21:25 +0000, JK Chen wrote:
> Where should the new code be inserted to?
> Thanks.
> JK
> From: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Bart
> van den Eijnden
> Sent: Tuesday, August 16, 2011 11:28 AM
> To: Joel Leininger
> Cc: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Formatting output text
> You could override the toString method of LonLat:
> OpenLayers.LonLat.prototype.toString = function() {
> return ("N " + this.lat.toFixed() + ", E " + this.lon.toFixed());
> Best regards,
> Bart
> OSGIS - http://osgis.nl
> On Aug 16, 2011, at 7:21 PM, Joel Leininger wrote:
> How do I go about reformatting the text output from a coordinate
> variable?
> In other words, I have output from a mouse position which has been
> transformed into different coordinate systems, and then gets displayed
> on the screen.
> It now looks something like this:
> lon=414614.58552010887,lat=164066.82345258445
> In reality, the values are x and y coords in feet or meters, not
> lonlat coords. I'd like them to look like this:
> N 164066, E 414614
> Note the truncation of the digits and switching of the x, y (which is
> customary in my field). Not being a JS expert, I can't figure out how
> to get at the variable to massage the format prior to display on the
> screen.
> Here's the code leading up to the display (inside of a mousemove
> function):
> mousepos = map.getLonLatFromViewPortPx(e);
> var NAD83ft_values = mousepos.clone(); // done several times for
> different coord translations
> NAD83ft_values.transform(WGS84_google_mercator, NAD83ft_proj);
> document.getElementById("NAD83feet").innerHTML = NAD83ft_values;
> It's unpacking NAD83ft_values that has me thrown. Any help?
> -J.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
