[OpenLayers-Users] Internet Explorer doesn't refresh vector layer
Michael mdm at yachtpc.com
Fri Aug 19 11:05:34 EDT 2011
I have found that, in many instances, the order that scripts or
functions are invoked can be very sensitive in IE.
This can affect variable scope, as well as whether an object or value is
properly passed to a function or object such as an ajax call.
Try starting your ajax cycle much later in your timeline.  I put mine at
the bottom of the page in a separate little block of script.
Best of luck
Michael
On 8/19/2011 8:01 AM, fabiowebby wrote:
> Hi Guys,
> I have a strange problem with IE that is driving me nuts and I really hope
> that someone can help me. I have some earthquakes data coming out of the
> database through php and is showed in a tabular manner. The results in the
> table are paginated in an ajax way. everytime page results are shown, a
> georss file is updated with the current page results so that openlayers can
> read it and show just the current page results not all them at the same time
> and assign different style for different earthquakes.
> I have a page called pagination.php with the following code:
> //file involved in ajax request and refresh
> <div id="loading"></div>//div to show loading img
> <div id="map" style="width:512px; height:256px; float:right;"></div>// map
> <div id="container">
> <div class="data"></div>//table results are shown in here
> <div class="pagination"></div>//pagination buttons are loaded in here
> </div>
> Also when pagination.php is called for the first time a map is created in
> the body in the following way and the first 25 results are read from the
> georss file:
> Now in pagination.php I import a file called pagination.js that hosts
> several jquery functions including the one for the ajax call.
> //this function is used to extract get variables values from the url
> function getUrlVars() {
> 				var vars = [], hash;
> 				var hashes = window.location.href.slice(
> 						window.location.href.indexOf('?') + 1).split('&');
> 				for ( var i = 0; i<  hashes.length; i++) {
> 					hash = hashes[i].split('=');
> 					vars.push(hash[0]);
> 					vars[hash[0]] = hash[1];
> 				return vars;
> //this function is involved in refreshing the vector layer but doesn't work
> in IE
> function refresh(){
> 				earthquakes.refresh({url:"files/georss.xml"});
> 				map.zoomToMaxExtent();
> //function to show loading img
> function loading_show() {
> 				$('#loading').html(" images/loading.gif ").fadeIn(
> 						'fast');
> //funtion to hide loading img
> function loading_hide() {
> 				$('#loading').fadeOut('fast');
> //function with ajax call to load data results in data div
> function loadData(page) {
> 		loading_show();
> 			$.ajax( {
> 				type : "GET",
> 				url : "load_data.php",//file that queries database and outputs results
> 				//get variables taken from url and passed to load_data.php
>                                  data : "page=" + page + "&start=" +
> getUrlVars()['start']
> 						+ "&end=" + getUrlVars()['end'] + "&minMagn="
> 						+ getUrlVars()['minMagn'] + "&maxMagn="
> 						+ getUrlVars()['maxMagn'],
> 				success : function(msg) {//if request is successful
> 					$("#container").ajaxComplete(
> 							function(event, request, settings) {
> 								loading_hide();//hide loading img
> 								$("#container").html(msg);//send data to container div
> 							refresh();//refresh vector layer
> 			loadData(1); // For first time page load default results
>                         // defines how to send the number of page to loaddata
> function
> 			$('#container .pagination li.active').live('click', function() {
> 				var page = $(this).attr('p');
> 				loadData(page);
> The result of all this shoulf be that the vector layer, where the georss
> points are shown,should refresh every time the ajax request for a new page
> results is successful. Now this arrangement works very well in Firefox and
> georss with diffrent style are refreshed according to the current page
> results. In IE the vector layer reads the file when the page is called for
> the first time and then when I click for successive pages the map does not
> refresh at all. Could anyone please help me with this? it is driving mental
> because I don't understand why IE doesn't understand the refresh function.
> Thank you very much in advance for your help.
> Best Regards
> Fabio
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Internet-Explorer-doesn-t-refresh-vector-layer-tp6703517p6703517.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
