AW: [OpenLayers-Users] getfeatureinfo mapserver show only the atributname
Arnd Wippermann arnd.wippermann at web.de
Mon Aug 22 17:59:25 EDT 2011
In your body template you need for every field, you want to show, an entry:
<tr><td>Field1</td><td>[Field1]</td></tr>
<tr><td>Field2</td><td>[Field2]</td></tr>
<tr><td>Field3</td><td>[Field3]</td></tr>
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von boho
Gesendet: Montag, 22. August 2011 19:12
An: users at openlayers.org
Betreff: [OpenLayers-Users] getfeatureinfo mapserver show only the
atributname
is there anything that can help me display the data from. dbf with
OpenLayers getfeatureinfo function ..
I've tried it but it appeared only the name attribute This is my OpenLayers
code:
<script type="text/javascript">
	function init(){
		var lon = 99.09668;
				var lat = 2.890000;
				var zoom = 12;
		var map = new OpenLayers.Map('map');
		var layer = new
OpenLayers.Layer.WMS('Batas_Kab_region','http://localhost/cgi-bin/mapserv.ex
e?map=C:/ms4w/Apache/htdocs/cobaLabel/batasKab.map&;',{layers:'Batas_Kab_reg
ion'});
		var bank = new
OpenLayers.Layer.WMS('BANK','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4
w/Apache/htdocs/cobaLabel/batasKab.map&;',{layers:'BANK'});
		map.addLayer(layer,bank);
		map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
		map.events.register('click', map, function (e) {
    var url =
'http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/cobaLabel/ba
tasKab.map&'
      + "?REQUEST=GetFeatureInfo"
      + "&EXCEPTIONS=application/vnd.ogc.se_xml"
      + "&BBOX=" + map.getExtent().toBBOX()
      + "&X=" + e.xy.x
      + "&Y=" + e.xy.y
      + "&INFO_FORMAT=text/html"
      + "&QUERY_LAYERS=Batas_Kab_region"
      + "&LAYERS=postgis:Batas_Kab_region"
      + "&FEATURE_COUNT=50"
      + "&SRS=EPSG:900913"
      + "&STYLES="
      + "&WIDTH=" + map.size.w
      + "&HEIGHT=" + map.size.h;
    window.open(url,
      "getfeatureinfo",
      "location=0,status=0,scrollbars=1,width=600,height=150"
this my mapfile :
# Map file created from QGIS project file C:/Program Files/Quantum GIS
Enceladus/as'.qgs # Edit this file to customize for your map interface #
(Created with PyQgis MapServer Export plugin) MAP
  NAME "QGIS-MAP"
  # Map image size
  SIZE 400 200
  UNITS meters
    EXTENT 96.802857 1.212928 102.390585 3.803407
  FONTSET './fonts/fonts.txt'
  SYMBOLSET './symbols/symbols.sym'
  PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 255 255
  IMAGEQUALITY 95
  IMAGETYPE png
  OUTPUTFORMAT
    NAME png
    DRIVER 'GD/PNG'
    MIMETYPE 'image/png'
    IMAGEMODE RGBA
    EXTENSION 'png'
  END
  # Legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
  WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH 'C:\ms4w\Apache\htdocs\cobaLabel\tmp\'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL 'C:\ms4w\Apache\htdocs\cobaLabel\tmp\'
    # WMS server settings
    METADATA
      'wms_title'           'QGIS-MAP'
      'wms_onlineresource'
'http:/localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/cobaLabel/bat
asKab.map'
      "wms_srs"   "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
	"wms_abstract"      "This demonstration server was setup by DM
Solutions
Group (http://www.dmsolutions.ca/) and is powered by the UMN MapServer
(http://mapserver.gis.umn.edu/).  This server uses Canadian source data
(c)2000, Government of Canada with permission from Natural Resources Canada
from NRCan's GeoGratis web site (http://geogratis.cgdi.gc.ca/)."
"wms_feature_info_mime_type" "text/html"
'wms_include_items'  'all'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See
    TEMPLATE 'http://localhost/cobaLabel/template/template.html'
  END
  LAYER
    NAME 'Batas_Kab_region'
    TYPE POLYGON
    DUMP true
	LABELITEM "KECAMATAN"
    DATA 'C:/ms4w/Apache/htdocs/siantar/Batas_Kab_region.shp|layerid=0'
    METADATA
      'wms_title' 'Batas_Kab_region'
     "wms_dataurl_format" "text/HTML"
    "gml_include_items"     "all"
    "gml_exclude_items"     ""
    "ows_include_items"     "all"
    "ows_exclude_items"     ""
    "wms_exceptions_format" "application/vnd.ogc.se_xml"
  'wms_srs'             'EPSG:4326'
    END
    STATUS ON
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       STYLE
         SYMBOL 0
         SIZE 7.0
         OUTLINECOLOR 0 0 0
         COLOR 78 109 18
       END
     LABEL
      FONT vera
      TYPE truetype
      SIZE 12
      COLOR 0 0 0
      ANGLE 0
      BUFFER 1
      POSITION cc
      FORCE true
      ANTIALIAS true
      PARTIALS true
     END
    END
  END
END
and this my template web :
&lt;!DOCTYPE HTML PUBLIC &quot;-//W3C//DTD HTML 4.01 Transitional//EN&quot;
       &quot;http://www.w3.org/TR/html4/transitional.dtd&quot;;&gt;
<html>
  <head>
  <meta http-equiv="content-type" content="text/html; charset=UTF-8"></meta>
    <title>GetFeatureInfo example</title>
  </head>
<body>
<table>
<tr>
<th>KECAMATAN:</th>
</tr>
The body template file;
<tr>
<td>[KECAMATAN]</td>
</tr>
and the Footer template file;
</table>
</body>
</html>
pleasee somebody help me....
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/getfeatureinfo-mapserver-show-only-th
e-atribut-name-tp6712417p6712417.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
